Rocker Panel Mouding Install
Old Jun 9, 2007 | 04:27 AM
Rolands64.5's Avatar
Rolands64.5
Default Rocker Panel Mouding Install
Hi, have a 64.5 Conv. just bought some Rocker Panel Moudings to dress up my car.Does anyone know how to install these moudings,came with no instructions.It came with 2 bags of hardware(bunch of clips and pop rivets).Any Info. would be appreciated.Thanks Roland.
Old Jun 9, 2007 | 12:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Rocker Panel Mouding Install
See if this helps. If not, then you don't owe me a beer.
http://www.hondapartsdeals.com/Honda...rpaneltrim.pdf
Old Jun 9, 2007 | 12:16 PM
JamesW's Avatar
JamesW
Those clips are installed along your lower rocker panel, front fender, and quarter panel. You must drill through the skin of the car and pop rivet the clips in place. Then the moulding snaps over.
There are probably several people here on the site that can take photos of theircar with the panels removed to show the factory placements....even take measurements.
I would ask tho, this is a mod that will drill holes in your skin panels. If you decide to ever take them off, it's a much more significant effort to go back.
Did you consider lower GT stripes?
Old Jun 9, 2007 | 03:09 PM
gothand's Avatar
gothand
IIR, the end clip on the front and rear bolt to the fender and rear quarter panel, respectively. The middle clips are indeed riveted in place. Your best bet is to measure one that is already installed.
Old Jun 9, 2007 | 03:35 PM
Rolands64.5
Default RE: Rocker Panel Moulding Install
HI, Does anyone have A picture or drawing with the moulding off and the clips exposed.Thanks.
mtgldr
Feb 3, 2024 09:00 PM
GPR
Dec 16, 2015 12:21 PM
copestang
Oct 11, 2015 07:17 AM
uedlose
Sep 30, 2015 08:01 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
