Question, Window Regulators
Old Jun 9, 2007 | 01:57 AM
kaiser18's Avatar
kaiser18
Default Question, Window Regulators
Iam a little new to the world of car mechanics so please bare with me.
Some how the window on the driver side of my 69fastback has come loose. At this point I can physically slide the glass to the left or right. I was wondering how difficult it is to take off the panels of the door and fix this my self.
Thanks.
Old Jun 9, 2007 | 05:35 AM
andrewmp6's Avatar
andrewmp6
Default RE: Question, Window Regulators
id pull off both door panels and use the right one to compair see if anythings missing or loose
Old Jun 9, 2007 | 11:32 AM
Soaring's Avatar
Soaring
I ♥ Acer
Take the door handle and window handle off by using an appropriate allen wrench. Use a phillips screwdriver to take the arm rest off. Then use something with a big blade like a big putty knife to work the outside edges of the door panel off. Once the door panel is off, you will see that the window has come loose from the channel.
http://www.mustangmonthly.com/techar...hannels_seals/
Old Jun 9, 2007 | 03:20 PM
kaiser18's Avatar
kaiser18
Thanks for the replys
Iam not sure if its true but i have heard thaton the1969models, the window was glued into the channel while the 1970s model was bolted in. If this it true it might be worth it to use a 70s regulator.
Old Jun 9, 2007 | 06:43 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yes, but then you would have to buy new glass. 3M makes an adhesive for this application. Do some research and save yourself some coin.
DreadPirateRoberts
Sep 26, 2015 02:11 PM
Meystang
Sep 25, 2015 04:05 PM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
