A/F Ratio Going Lean!
Old Jun 9, 2007 | 03:58 PM
smbikes's Avatar
smbikes
Default A/F Ratio Going Lean!
I put a 650 Dp Holley on my car and im in the process of tuneing it , ipurchased a Innovate Motorspots Wide Band tuner and ran a few test to day , at idle im am at about 12.1 , as i raise therpm solwley up to 5000rpm it it wil raise to a max of about 13.0 , but when i floor it or give it about 1/2 Throttle at a fast rate it jumps lean to about 20.1 at the max for about 1sec and stumbles. Also when i going Downthe road and give it some gase it wil go lean to about 16.1 and stumble.
any idea on what needs to be done?
Old Jun 9, 2007 | 05:57 PM
VeronicaScz's Avatar
VeronicaScz
Default RE: A/F Ratio Going Lean!
Hello.I think that I would start out by adjusting the accellerator pump linkage arm and maybe swap out the power valve with one that opens a little quicker.Hope that helps.
Old Jun 9, 2007 | 08:07 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Accelerator pump cams and squirters would be my first choice. After the engine doesn't stumble just by stabbing the throttle in neutral, start adjusting the power valve when driving the car to get rid of the part throttle stumbles.
Old Jun 9, 2007 | 10:33 PM
67coupe's Avatar
67coupe
Install a larger squirt nozzlefor the accelerator pump? I use a #31.
Old Jun 10, 2007 | 02:16 AM
mikethebike's Avatar
mikethebike
ORIGINAL: smbikes
I put a 650 Dp Holley on my car and im in the process of tuneing it , i purchased a Innovate Motorspots Wide Band tuner and ran a few test to day , at idle im am at about 12.1 , as i raise the rpm solwley up to 5000rpm it it wil raise to a max of about 13.0 , but when i floor it or give it about 1/2 Throttle at a fast rate it jumps lean to about 20.1 at the max for about 1 sec and stumbles. Also when i going Down the road and give it some gase it wil go lean to about 16.1 and stumble.
You are experiencing the dreded 'lean-out-bog'Is the unit based on an 02 sensor or an EGT? I tried an Edelbrock a few yeas back that used the 02 from a Ford and it reacted about 1000 times too quickly.
The accel pump has 2 positions, try the other one. Also take a vacum reading, subtract 5 and that should put you spot-on for the power valve.
Old Jun 10, 2007 | 07:32 PM
smbikes's Avatar
smbikes
Update: did some changes , pkayed with the air setting and put 31 squirtes in both sidesand got it to idle at 14.7 and revingin neutral it took the gas better with out going so lean but on the road it was still going very lean , did a vac reading and got 11hg , it had a 6.5 Pv in it , whent to the Autoparts and they only had a 4.5 so igot it and tried it and it seems worse,
Ideas??
smbikes's Avatar
smbikes
Ps . It has a proform main body
Old Jun 10, 2007 | 07:36 PM
smbikes's Avatar
smbikes
Also what do u think about the 1:1 linkage
Old Jun 10, 2007 | 07:37 PM
mikethebike
ORIGINAL: smbikes
Update: did some changes , pkayed with the air setting and put 31 squirtes in both sides and got it to idle at 14.7 and reving in neutral it took the gas better with out going so lean but on the road it was still going very lean , did a vac reading and got 11hg , it had a 6.5 Pv in it , whent to the Autoparts and they only had a 4.5 so i got it and tried it and it seems worse,
Ideas??
The 4.5 only made it leaner.....it opens at 4.5 in of vac and the 6.5 opened 2in sooner. Have you checked for vac leaks around the base of the carb? If you have 14.7vac at idle you need a 9.5 power valve or a 10.5 like came stock in a Ford 4 barrel.
Remember....subtract 5 from your vac at idle and this is where you should be for your power valve.
Old Jun 10, 2007 | 07:54 PM
smbikes's Avatar
smbikes
so i need a 5.5 , i have not check for a leak around my carb yet.
