Outer wheelhouse removal
Old Jun 9, 2007 | 11:18 PM
RGH69's Avatar
RGH69
Default Outer wheelhouse removal
We are replacing several sheetmetal parts on the 70 FB and ran into a problem while trying to remove the right rear outer wheelhouse. There is some kind of crimped weld between the inner and outer wheelhouses. What is the best way to seperate these? Anyone done this before?
Old Jun 9, 2007 | 11:22 PM
Tony R's Avatar
Tony R
Default RE: Outer wheelhouse removal
If its anything like the 65 I drilled out all of the spot welds.
Old Jun 9, 2007 | 11:26 PM
RGH69's Avatar
RGH69
There are spot welds and we drilled those out. But there is some kind of crimped seam weld along the entire flange holding the two halves together.
Old Jun 9, 2007 | 11:29 PM
Tony R's Avatar
Tony R
have you tried an air chisle?
amchief's Avatar
amchief
I just finished doing both sides of mine, Its a 70 fb also.
The only thing I had was a bunch of spot welds holding them together, the metal was crimped on the back section in side the trunk area, but after removing the spot welds it seperated.
Old Jun 11, 2007 | 01:19 PM
RGH69's Avatar
RGH69
Well, we tried an air chisel.....no workie. So we took a cutoff wheel and cut out what we could, then ground it down with a flapper disk. We could not get the flapper disk in between the roof support so there will be an extra layer of metal at that point. If we do the other side we will replace both the inner and outer instead of messing with it.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
guitarman376
Oct 11, 2015 01:47 AM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
