Identify 3rd member gears
Old Jun 11, 2007 | 12:02 AM
ericdudeus's Avatar
ericdudeus
Default Identify 3rd member gears
Hello -
My first post to this forum and I hope someone can help me out. I have 2, 8" rear-ends and neither set has the bolt-on ID tag, is there another way of identifying them? Thank you!
Eric
Old Jun 11, 2007 | 12:41 AM
colostang's Avatar
colostang
Default RE: Identify 3rd member gears
I don't know, but bump bump, because I do want to know.
Old Jun 11, 2007 | 01:55 AM
andrewmp6's Avatar
andrewmp6
read this http://www.mustangsplus.com/tech/axles/index.htm or open it up and you divide the # of teeth on the ring gear by the # of teeth on the pinion gear to get the raito.
Old Jun 11, 2007 | 03:23 AM
gothand's Avatar
gothand
From drivetrain.com
To determine your existing gear ratio:
Place transmission in neutral and elevate one tire. Mark tire and driveshaft, turn tire two complete revolutions while counting number of turns of the driveshaft. This is your Actual Gear Ratio. i.e. 3 turns + 3.00 ratio, 4.1 turns = 4.1 ratio, etc.
Coyote_hpr
Nov 12, 2019 12:44 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
popsotto
Sep 28, 2015 06:58 AM
2poor4u2
Sep 26, 2015 11:08 AM
