rebuilding steering valve
Old Jun 13, 2007 | 12:48 PM
arthur's Avatar
arthur
Default rebuilding steering valve
i am trying to get the steering valve apart ( powersteering mustang 1966) but i got stuck:
any suggstions to get this apart.. without ruining it [8D]
update: i already got the front off... noticed a little pin that blocked taking of that front... now i only need to get that balljoint out.. i can move it freely in it's " housing" but still can't get it out.. atleast not without using force to pull out
i got this far:
you might wanna ask why the heck do i want that balljoint out... well.. i got a rebuild kit that contains a new balljoint.. so i wanna use it too
tia
arthur
Old Jun 13, 2007 | 01:27 PM
highhilleer's Avatar
highhilleer
Default RE: rebuilding steering valve
A couple of sites for your reading pleasure
http://www.stangerssite.com/
http://www.mustangmonthly.com/howto/91338/index2.html
Old Jun 13, 2007 | 02:31 PM
arthur's Avatar
arthur
thanks.. interestings article/site.. .. but still couldn't find if or how to get that balljoint out [sm=dontgetit.gif]
arthur
Old Jun 13, 2007 | 02:37 PM
stanger53's Avatar
stanger53
The bronze bushing needs to go farther into the end of the centerlink. It may not easily slide in, but it will go. Once the bushing is in far enough, the slot in the bushing where the ball stud goes becomes a hole and you can lift the ball stud out.
If you have a Ford shop manual that shows the ball stud laying down inside the bushing and sliding out with it, the manual is wrong. They stopped making valves like that in the late 50's.
Be sure that the new bushing you are putting in slides smoothly in the end of the centerlink ALL THE WAY. Yours is probably binding right now because the sleeve of the centerlink is out of round or bent.
Old Jun 13, 2007 | 03:29 PM
arthur's Avatar
arthur
got it out.... indeed the edges of the sleeve was a bit bent... just with a lil force i could take the balljoint out
unfortunately there is no new sleeve in the kit..... on the balljoint you can see plety of rustpits.. atleast good thing to replace that
Old Jun 14, 2007 | 12:45 AM
stanger53's Avatar
stanger53
You really need to replace that bushing. It is so worn that the steel backing is showing. Not only will that make the bushing loose in the sleeve, it will wear grooves in the sleeve quickly, if it hasn't already.
Old Jun 14, 2007 | 09:08 AM
arthur's Avatar
arthur
ORIGINAL: stanger53
i follow your advice... will get a new sleeve socket (bushing)
arthur
Old Jun 14, 2007 | 06:12 PM
arthur's Avatar
arthur
i couldn't wait to get the valve back together so i got the new socket this afternoon right away...
if compare both sockets it is quite obvious that old one was really worn out... speccially on the edges on the left where the ball is located
and in meantime the valve put back together with all the new parts.... and can say now that it was certainly needed to rebuild it.
arthur
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
CS2007
Jun 25, 2019 09:45 PM
ChampInSD
Oct 2, 2015 04:55 AM
Drastang
Sep 30, 2015 03:48 AM
