need electrical help
well the PO wired it up to put a newer radio in but the radio he had was crap and didnt have speakers. i took it out and it has a red and black obviously the power and ground. those wires have a small black box with and in line fuse in it. the thing is that the fuse says 8A. 8A???? never seen one and can't find one at any store. can i just put a 10A fuse or will it fry the wires or something. what do i do??? I NEED MUSIC!!!
https://mustangforums.com/m_3374624/tm.htm
Here is a very recent thread dealing with this subject. I think a 1 or 2 amp fuse would do. Check the instructions for your new radio to make sure.
The orig wires from the car are different, there is a black, but it is power +, the other color is not red unless ithas beenreplaced.
Get a test light or a multimeter to verify the switched power.
Google is your friend. Here is your 8 amp fuse.
http://www.nextag.com/8-amp-fuse/search-html
Is it a maxi style (plastic) or a glass style? I would "one" lower if you can't find the right one. 10A is a lot of current for the wire that would have been used on an old type radio...If you can read the side of the wire I can tell you the max current that the wire will handle...
Yeah, 10 amps to a radio is a lot of juice before the fuse blows. You can get creative and go to wal-mart or radio shack and get an inline fuse for just about any amperage you desire. I would use whatever the radio manufacturer recommends. If it's 8 amps, then so be it. You can't say they are not available.
mrappe
Sep 26, 2015 10:16 AM
uberstang1
Sep 20, 2015 06:42 PM
TfcCDR
Sep 14, 2015 12:08 PM
