warped valve?
Old Jun 14, 2007 | 09:13 PM
jroseman's Avatar
jroseman
Default RE: warped valve?
yea, the bent valve stem is what seem to be most likely. man - can't i just drive the car for a while without spending money.
was saving for a t5, but, life goes on.
summit does not list a rpm for a 67, 289. the twised wedge is 1200 but has a 61cc. my stock 289 (ported) heads are between 52 and 55.afr cc is 58.
Old Jun 14, 2007 | 09:18 PM
Tony R's Avatar
Tony R
I had a similar problem once. It was the valve seat that came loose. So every once in a while the valve would get stuck because the seat fell out of place and after idleing for a moment it would pop back in place. luckily for me it didnt hit a piston so all I had to do was replace the head.
Old Jun 14, 2007 | 09:25 PM
JMD's Avatar
JMD
ORIGINAL: Tony R
Very, very likely that this happend, didn't think of it before. Makes a lot of sense.
Old Jun 14, 2007 | 09:27 PM
jroseman's Avatar
jroseman
the edelbrock are $1100 but require fly cut pistons. mine are flat top with the 4 notches - i think that is fly cut. the cc is 60.
the afr heads are 1325. 58cc. not that much differnce.
not that much difference in price, that is. they are the best by in every article i have read. and only 200 to 300, a small long difference for a term investment.
Old Jun 15, 2007 | 09:03 AM
Norm Peterson's Avatar
Norm Peterson
AFR will mill the heads to get back at least part of the lost compression as an "regular" option. 5cc is a little over half a point in CR in this size engine. That they are aluminum vs your current iron ones, a little more CR may be possible, although things like piston/valve clearance and pushrod length become a bit more critical.
Norm
Old Jun 15, 2007 | 04:26 PM
boogerschnot's Avatar
boogerschnot
Sounds like the spring was weak or the seat moved,, Did you readjust the rockers after 500 miles or so, when you got the heads rebuilt. If they replaced the springs and it wasnt broken in correctly then you could have weakened the spring and most likely bent the valve stem
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
lmurf60
Sep 24, 2015 10:07 PM
TfcCDR
Sep 14, 2015 12:08 PM
