rust
Old Jun 15, 2007 | 06:55 PM
RGH69's Avatar
RGH69
Default RE: rust
Looks like they tried to fix some rusty spots or patched by brazing. Brazing will cause disimmilar metal corrosion. The bad news is that there are probably other hidden brazing treasures. You will have to cut out those sections and getthem patched and welded in correctly. Fun Fun
Old Jun 15, 2007 | 07:16 PM
Tony R's Avatar
Tony R
Default RE: rust
I have already found many similar spots. I will hopefully finish sand blasting this weekend. I have the undercarriage blasted and the bottom half of the engine compartment. Even though I spent weeks scraping undercoating it is still a pain to remove the remaining residue with the blaster. Then the layers of bondo dont strip too easily. I am paying someone to strip my next car. I feel for you grimm but I have already cut out and replaced alot of that cancer and am finding more hidden under the paint that the PO painstakenly covered so nicely for me to find.
Old Jun 16, 2007 | 03:14 AM
Tony R's Avatar
Tony R
Default RE: rust
I pulled the door today and found this. It was a combination of brazing and bondo.
[IMG]local://upfiles/64293/E9DF007C5BAC4A5DA1CDE577B8699234.jpg[/IMG]
Old Jun 16, 2007 | 03:22 AM
green_blurr's Avatar
green_blurr
Default RE: rust
Tony i had the same problem someone had the door open and backed up with it and slamed the hinge and cracked that column and they brazzed it you need to melt that all off and mig weld it back up and grind it back down.
Old Jun 16, 2007 | 03:25 AM
Tony R's Avatar
Tony R
Default RE: rust
I found a donor at the local mustang shop. He is going to let me cut it out and a couple other parts I need. I would feel better replacing it than trying to put a band aid on it.
Old Jun 17, 2007 | 02:04 PM
ponyx2's Avatar
ponyx2
Default RE: rust
YIKES!
ORIGINAL: Grimm
Here you go Tony.
These should make you feel a little better about your situation!
[IMG]local://upfiles/52170/AA037FEC16D44BB9B193A3E58837B928.jpg[/IMG]
[IMG]local://upfiles/52170/DB632958FD8A4FBA86E9E772ED6B4EFA.jpg[/IMG]
[IMG]local://upfiles/52170/721FD1DF61FF4142A82D710FDD88EB63.jpg[/IMG]
[IMG]local://upfiles/52170/B89792D4E1A3487B8B78473226771544.jpg[/IMG]
Old Jun 17, 2007 | 08:10 PM
Astrawn's Avatar
Astrawn
Default RE: rust
For a minute Grimm, I thought you stole my 66 and took pictures! Rust, oh how I love it so! Remember TonyR, 40+ years old!
Old Jun 17, 2007 | 08:21 PM
baddog671's Avatar
baddog671
Default RE: rust
Rust hates us all...
http://i32.photobucket.com/albums/d9...g?t=1182118718
Thats the inside of my suspension tunnel, the little "cup" that holds dirt and other crap off the road. Looked even worse when I took the loose rust/dirt/scale off it...
GPR
Dec 16, 2015 12:21 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 17, 2015 07:57 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
