Radiator ?
Old Jun 18, 2007 | 10:49 AM
thunderize's Avatar
thunderize
Default Radiator ?
If I remove my radiator cap and start my car should I see the coolant moving? When I do this I dont see any movement. Does this mean the radiator is plugged up or does it mean the water pump is not working? Thanks
Old Jun 18, 2007 | 11:06 AM
73 Sportroof's Avatar
73 Sportroof
Default RE: Radiator ?
You won't see movement until it is up to temp, and the thermostat opens.
Old Jun 18, 2007 | 05:28 PM
thunderize's Avatar
thunderize
Thank you!
Old Jun 18, 2007 | 08:15 PM
urban_cowboy's Avatar
urban_cowboy
Remember to have someone working the throttle, or the cooling system is going to dump a bunch of coolant on the ground when the thermostat opens.
Old Jun 18, 2007 | 09:34 PM
Soaring's Avatar
Soaring
I ♥ Acer
The coolant won't dump any coolant on the ground if the system is set up properly.
Old Jun 19, 2007 | 02:14 PM
thunderize's Avatar
thunderize
Soaring what do you mean by set up properly?
Old Jun 19, 2007 | 02:55 PM
urban_cowboy
Everytime I have run an engine without the cap on the radiator, it will eventually over flow out of the neck unless someone is pushing on the throttle. I admit I could be wrong, but I have always thought that is due to the system trying to pressurize when the thermostat opens. When the throttle is low, the pressure increases.
Granatelli Sales
Jan 20, 2020 12:34 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Beerman309
Sep 19, 2015 01:16 AM
MusicCity615
Sep 12, 2015 07:05 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
