65 or 67 Battery tray
ORIGINAL: gothand
With that mod you can fit a larger radiator if you so desire. If you're staying with the stock sized radiator, I'm not sure if there is a benefit.
Taylor makes a nice polished aluminum battery relocation kit for about 80 bucks. Same as the 200$ Steeda kit without the name embossed on the cover. Dunno how much the power wire would cost for that extra distance, but it would convert weight off the nose to above the wheel and give you more engine bay room...
It really depends if you need the space or where you need the space. If you want a bigger radiator use the 67 tray. If you like the stock look and don't have room issues go with a 65 66 tray you already have the holes for it? If you need a lot of space and don't mind paying a few bucks trunk relocation may be right up your alley. There are kits that do a good job of giving you a decent price and plenty ofwire for the job at hand. So once again, it all comes down to you...
logan409
Sep 26, 2015 07:43 PM
