rotella - engine oil
Old Jun 23, 2007 | 12:50 PM
jroseman's Avatar
jroseman
Default rotella - engine oil
i was reading the post on engine oil posted earlier and i noticed that no one said they use rotella in their older mustang with flat tappet cam. does anyone out there not use the rotella?
Old Jun 23, 2007 | 01:03 PM
JMD's Avatar
JMD
Default RE: rotella - engine oil
There are lots of folks who use other oil I am sure, but if you are breaking in a new flat tappet cam and lifters, I highly recomend it.
We are using this oil for break in on my son's engine, even though we are using a roller cam.
Old Jun 23, 2007 | 01:05 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
I use it. New 351W. Had it in there for about 2000 miles. No problems.
Old Jun 23, 2007 | 02:27 PM
jroseman's Avatar
jroseman
will you continue to use it after break- in?
Old Jun 23, 2007 | 02:47 PM
JMD's Avatar
JMD
If we don't switch to synthetic, we will run the Rotilla.
We will prob go synthetic after break in though.
Old Jun 23, 2007 | 03:10 PM
jroseman's Avatar
jroseman
will you still change at 3000? i have all my life and don't think i could bring myself to go further.
Old Jun 23, 2007 | 03:27 PM
JMD's Avatar
JMD
ORIGINAL: jroseman
No, had a truck when I was very young, I did change the oil at no more than 3,000 miles for quite a while, but I started really looking at that brown oil I was throwing away, and decided it was a waste.
Later I went way the other way,,,,, (see my other post on oil and my 90 chevy), Now I am in the middle somewhere, I have no problem with going to 10,000 miles between changes, and that is about where I change at, fithin a few thousand.
If we are talking a "performance engine" Ichange at about 6,000. (performance here = no where close to stock)
Old Jun 23, 2007 | 03:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
When I was running conventional oil I used Rotella. It is supposed to be the best dino oil on the market. I'm running Royal Purple in both my Mustangs now and am very pleased with it.
Old Jun 23, 2007 | 03:56 PM
JMD's Avatar
JMD
ORIGINAL: Soaring
I have been running Rotella in trucks for many, many years. It is a very good product. I use either Rottela or Mobile Delvac in trucks.
I have found that the Delvac will raise the oil pressure a little on worn engines. (about 5 lbs or a little more.)
Old Jun 23, 2007 | 04:42 PM
Stevetra's Avatar
Stevetra
Wow...I had no idea Rotella, and Delvac we avalible in part stores for cars...
It must be good because most piston aircraft use one or the other.
We had a Cessna 421 Golden Eagle that ran the Delvac oil, the engines were twin turbo charged contenentals, and our Piper Aztecs ran the Rotella, normaly asperated lycomings.
I always assumed that those two names brands were some special aircraft oil...huh...live and learn.
