My car won't turn off?
Old Jun 24, 2007 | 03:36 AM
JJ68Mustang's Avatar
JJ68Mustang
Default My car won't turn off?
After I turn the key off, the engine keeps turning over... poorly, but turning over nonetheless. It does it a couple of times then decides to die... any idea what's going on?
Old Jun 24, 2007 | 03:38 AM
mat11089's Avatar
mat11089
Default RE: My car won't turn off?
Timing is off....
Old Jun 24, 2007 | 03:41 AM
67mustang302's Avatar
67mustang302
Yeah, it's called deiseling, and it's usually caused by too much ignition timing
Old Jun 24, 2007 | 03:45 AM
mat11089's Avatar
mat11089
Yep getting a timing light on it and either go from there or let us kno what shes at.
Old Jun 24, 2007 | 03:51 AM
JJ68Mustang
That makes sense, I have a timing light, and I know how to use it! Thanks guys!
Old Jun 24, 2007 | 04:32 AM
superdavid's Avatar
superdavid
Its not the timing. When the ignition is off, there is absolutely ZERO spark still going down the wires. Your carb is probably idling too high, or running rich. Most likely the idle.
Old Jun 24, 2007 | 12:13 PM
JMD's Avatar
JMD
ORIGINAL: superdavid
+ 1,
And sometimes engines with compression ratios aproaching the upper limits for the pump gas being used will diesel. Sometimes engines can develop "hot spots" in the cumbustion chamber, sometimes these hot spots can be eliminated by using a "colder" sparkplug.
Old Jun 25, 2007 | 04:13 AM
JJ68Mustang
hmm... alright, I have some things to tinker with then... I'll see what I can do and get back to you... Thanks again!
MXBT187
Aug 20, 2015 02:36 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
