1966 head light problem
Old Jun 24, 2007 | 05:54 AM
stangkid66's Avatar
stangkid66
Default 1966 head light problem
my 1966 mustang convertible is having problems with the head lights. after i drive for about 10 minutes with the lights on they begin to turn off and on. there's no pattern to it just at random moments. any ideas? thanks
Colin
Old Jun 24, 2007 | 05:57 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: 1966 head light problem
You're overheating the headlight switch. Replace it and all will be good.
Old Jun 24, 2007 | 11:01 AM
JamesW's Avatar
JamesW
Yep...weak switch.
While you're at it... consider rewiring your headlights to use relays. This little mod let's you put the full battery current to your headlights (rather than incurring the power drop fromrouting through your old wiring harness) while still operating normally.
http://midnightdsigns.com/james/headlights.htm
It's really a simple mod and can be completely hidden.
Old Jun 24, 2007 | 11:04 AM
Soaring's Avatar
Soaring
I ♥ Acer
The first thing I would do would be to check the ground wires. Clean up the contact, etc., then if that didn't do the trick replace the light switch.
djbigskrilla
Sep 20, 2022 01:04 AM
KinneyD
Jan 9, 2016 05:33 PM
jjwinel78
Aug 17, 2015 03:34 PM
1st 4 eyed fox
Aug 15, 2015 02:16 AM
philster0306
Aug 10, 2015 11:33 AM
