headers and exhause for a 69 help!!
Old Jun 24, 2007 | 03:56 PM
fastbck429's Avatar
fastbck429
Default headers and exhause for a 69 help!!
does anyone have any recommendations for the headers and exhaust on 1969 mach1 mustang with a 351 windsor 4 speed thanks
Old Jun 24, 2007 | 05:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: headers and exhause for a 69 help!!
JBA long tube ceramic coated. 2 1/2" pipes with an "X" pipe.
Old Jun 24, 2007 | 05:42 PM
fastbck429's Avatar
fastbck429
i looked on their website and there were no long tube ceramic coated for a 69 with a 351 theyre all for 302s or 289s. does it really matter if i used ones for a 301? if someone could give me a link or something for them id really appreciate it. I did not see the x pipe exhaust either. links to these parts would help out alot
thanks soaring
Old Jun 24, 2007 | 07:54 PM
arkight's Avatar
arkight
http://www.fordpowertrain.com/FPAindex/FPA%20index1.htm
try them out
Old Jun 24, 2007 | 11:26 PM
Aussie66Fastback's Avatar
Aussie66Fastback
I wouldnt use long tubes on a street engine. better torque from tri-y style and better clearance in most cases. http://www.pacemaker.com.au/faq.html#design
btw, you need 351 headers for clearance...the deck height is slightly higher than a 302/289.
I am yet to be convinced of the benefits of an x-pipe on a street engine either. an h-pipe is a lot cheaper exercise.
are you planning on buying a kit and fitting it yourself?
we had a post on this topic a while back and the general consensus was to get a decent exhaust shop to make an exhaust for you. The main thing is to go to a guy with experience on these cars, not some "rice" shop that specializes in bolt on fart cans.
Old Jun 25, 2007 | 12:50 AM
andrewmp6's Avatar
andrewmp6
a tri y will give you more power a x pipe is always a good idea.aussie a x pipr helps suck the exhaust out more then a h does. and a x pipe has more power then a h.he is right find a good exhaust shop to run the pipes or buy a bolt on kit and do it yourself.
Old Jun 25, 2007 | 02:15 AM
Aussie66Fastback
yeh i get how the x is supposed to work and it sounds like a good theory, but on a street engine i cant see it making that much difference. diffrent story ona race motor. I'd like to see before/ after dyno sheets with no other changes.
most factory twins have an h to balance. i've never seen a factory x. not raining on anyones parade, just never seen evidence that they are worth the extra $.
Old Jun 25, 2007 | 04:14 AM
andrewmp6's Avatar
andrewmp6
c5 and up corvette is a x i believe i think the newer mustangs do not really sure on that.mine im runing long tube headers with glass packs and turn downs before the axle no x or h pipe.
Old Jun 25, 2007 | 05:01 AM
Aussie66Fastback
i was runnign twin out the back, no h. changed it b/c i didnt like the exhaust note! Sounded like a speed boat.
my exhaust guy claims the h has a scavenging effect at best and balances the sound at worst. it def sounds better now, but no dyno to be sure of benefit.
I have a 351C in another car with no h and it sounds real lazy. one day i will rebuild that engine and try a few different combos
Old Jun 25, 2007 | 09:29 AM
palerider's Avatar
palerider
May want to post your question on below site - site specifically for 69/70s.
http://www.1969stang.com/main/
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
