*help with a 67 coupe*
Old Jun 26, 2007 | 09:43 AM
towins's Avatar
towins
Default *help with a 67 coupe*
I need some help with my 67 mustang, does it matter wat type of battery u use? can a normal style bat fit? do you need a spacer under the carby between the carby bottom and the motor? and any one from austraila with second hand spare parts (Vic) Thanks
Old Jun 26, 2007 | 10:41 AM
andrewmp6's Avatar
andrewmp6
Default RE: *help with a 67 coupe*
as long as its a 12 volt battery not a 6 youll be fine if you can get it to strap down.you dont have to run a carb spacer but they do help out alot.welcome to the forum theres alot of great people on here.please take the time to read the faq theres alot of good info in there well worth reading.
Old Jun 26, 2007 | 09:57 PM
67Sally's Avatar
67Sally
I recommend the carb spacer. As far as batteries go I would suggest using the search function. There was athread a while back on what batteries people were running and they spanned from expensive Optima Red Tops to common Autozone Duralasts.
Old Jun 27, 2007 | 07:29 AM
towins's Avatar
towins
cool thanks, that helps a bit
Old Jun 27, 2007 | 08:25 AM
paddy187's Avatar
paddy187
There are a few from down under on the forum who maybe can point u in the right direction regarding parts.
