Help question. How do you 'prime' 66 289?
Old Jun 26, 2007 | 01:48 PM
bignasty34's Avatar
bignasty34
Default Help question. How do you 'prime' 66 289?
I was told I need to prime the oil pump and need to buy a special tool? What kind of tool?
Do I need to prime anything else?
Thanks
Click https://mustangforums.com/m_3445908/tm.htmto see pictures of my Mustang!
Old Jun 26, 2007 | 02:12 PM
gothand's Avatar
gothand
Default RE: Help question. How to 'prime' 66 289 that has been rebuilt
You can either turn the oil pump driveshaft counterclockwise with a 1/4" socket (verify size) on a power drill or you can turn the vehicle over with all the spark plugs out. You want to run the pump until oil comes out of the top of the pushrods.
Old Jun 26, 2007 | 02:39 PM
boogerschnot's Avatar
boogerschnot
Like gothand said, just put a 1/4 socket on an electric drill with an extension and stick it in the hole where the distributor goes and pull the trigger.. If you look down in there you can see the pump drive.. Just dont drop your socket in there.. Or just pull the wire off the top of your distributor and turn the engine over with the starter to prime everything up.. ( dont pump the gas or you will flood it)
boogerschnot
And post some pics of that bad boy already!!
Old Jun 26, 2007 | 04:45 PM
bignasty34's Avatar
bignasty34
Thanks for the tips guys! I can't wait to go cruising in my Stang.
Updated with picture linkat the top!
Old Jun 26, 2007 | 08:50 PM
65StangFB's Avatar
65StangFB
If you are uneasy of using a socket, you can buy a oil pump shaft for about $4 from a local parts store. I bought one about 3 weeks ago, but have reched that stage yet.
Old Jun 26, 2007 | 08:54 PM
bignasty34's Avatar
bignasty34
The car, including the engine, are not finished. I just got it yesterday.
Old Jun 27, 2007 | 10:12 AM
Norm Peterson's Avatar
Norm Peterson
Be careful with the drill trigger and don't push it too hard. Oncethe pump primes, it requires more torque to turn, and lots more to pump the larger volume of oil that a high drill speed will try to move. If the chuck slips, little metal chips will fall down the hole (and will have to pass through the engine once just to get to the filter). This is particularly likely if you use a specific oil pump priming tool that has a drill chuck end small enough to fit into a 1/4" drill.
As a precaution, you could grind 3 flats on the end you stick in the chuck so that it won't slip. Maybe even "waste" a socket and that modified extension and tackweld them together so the socket can't fall off.
Norm
Old Jun 27, 2007 | 12:42 PM
pinboy122's Avatar
pinboy122
i always wrap electric tape on socket-extensions just to make sure it doesnt fall off
jwog666
Dec 27, 2021 08:09 PM
uberstang1
Dec 7, 2017 07:10 AM
GTJIM
Sep 23, 2015 09:59 AM
tramphardrocker
Sep 13, 2015 08:56 PM
ryland
Sep 13, 2015 12:35 PM
