Universal Wiring Harness
Old Jun 26, 2007 | 03:48 PM
1sick66's Avatar
1sick66
Default Universal Wiring Harness
If i got a universal wiring harness from ebay would that work fine in my 66 mustang??????
If so then how many circuits do i need to look for?
Old Jun 27, 2007 | 12:00 AM
JamesW's Avatar
JamesW
Default RE: Universal Wiring Harness
ORIGINAL: 1sick66
Sure it would work. It would be no different than wiring up a street rod. It would just be a lot of work*S*
I'd probably get a 15 circuit setup.
Old Jun 27, 2007 | 02:56 AM
bradleyb's Avatar
bradleyb
I think most aftermarket require dealing with ends and so forth so I don't see why a universal wouldn't work as well. Ron Francis is pretty inexpensive or you could spend a bit more and go painless. I got the Ron Francis and am starting into it now - I wish the ends and feed to the engine compartment would have had the stock type connectors (what to do then with the hole no longer being used........
Old Jun 27, 2007 | 03:51 AM
atomsk680's Avatar
atomsk680
ORIGINAL: bradleyb
rubber filler gasket thing?
i got the painless and honestly with painless, your just buying better wires, all labeled and bunched together so its easier to find what goes where, everything else is a PITA
Old Jun 27, 2007 | 04:24 AM
green_blurr's Avatar
green_blurr
So with the new harneses either painless or Ron francis they all will hook up to your old conection plugs like steering pigtail and ignition pigtial ect...?
Old Jun 27, 2007 | 04:42 AM
andrewmp6's Avatar
andrewmp6
green basicly yes you just have to put the wire conectors on the ends of the wires tho.they also make a oem replace one with the conectors on it but ita skinnier wires then painless and ron francis uses.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
