rust and stuff
Old Jun 26, 2007 | 10:57 PM
mortman's Avatar
mortman
Default rust and stuff
Looking for the best rust encapsulater product for those small rusted spots that don’t need to be cut out just cleaned and coated, Seen east woods items everywhere, bullet proof and POR 15. What is the best that will stop rust on my project in those small areas like front and rear window openings, parts of the floor pan ect. I’m in central cali so our weather is not that crazy.
TIA for any advice
Old Jun 26, 2007 | 11:20 PM
baddog671's Avatar
baddog671
Default RE: rust and stuff
I think the Rust Bullet warehouse is in CA. Either way, all options listed are good.
Old Jun 27, 2007 | 03:46 AM
atomsk680's Avatar
atomsk680
i got por15, worked great
Old Jun 27, 2007 | 02:16 PM
66GTKFB's Avatar
66GTKFB
POR-15 is a good product to use but - if you have rust problems and that rust goes under the rubber seal on your car's windows, you should remove the glass and thenapply the POR-15. It will not 'flow' under the rubber so your rust will still be there.
Jim
Old Jun 27, 2007 | 05:30 PM
dozierstang's Avatar
dozierstang
I've used both por 15 and eastwoods rust encapsulator. POR 15 is good and so is rust encap. But you are not required to top coat RE or required to use special thinning agents, cleaners, etc. on RE like POR 15. And RE is cheaper.
Old Jun 27, 2007 | 05:54 PM
scuf23's Avatar
scuf23
I have only used RE - worked very well, very easy to apply - I did use a top coat on top of it ... I attach2 pictures of my finished under carriage
[IMG]local://upfiles/62696/86B0F068547F40DD8D5300B55C23273B.jpg[/IMG]
[IMG]local://upfiles/62696/4F9BFEB967384BA38EF3BAD99DADF643.jpg[/IMG]
Old Jun 28, 2007 | 11:48 AM
mortman's Avatar
mortman
Thanks all fo rthe 411. 66GTFB - I should have mentioned thatIam removing the glass
Old Jun 28, 2007 | 12:46 PM
dozierstang
I used RE to recoat the undercarrage, but Iuse the original red oxide color and did not top coat and I don't plan to either.
EZFEED
May 5, 2016 08:54 PM
b8checker
Oct 8, 2015 12:55 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
b8checker
Sep 30, 2015 07:11 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
