Rim Blow Switch
Old Jan 11, 2005 | 06:36 PM
mach12004's Avatar
mach12004
Default Rim Blow Switch
Hi,
I finally started to repair the trunk floor and brace. I will try to post a picture. I was wondering about a different issue; has anyone ever replaced the infamous "rim blow" switch in there three spoke wheel? If you have could you comment on the correct procedure to install the new switch. Thanks. HSB
[IMG]local://upfiles/11074/4BE364DDB138457297681339DF6E1925.jpg[/IMG]
Old Jan 12, 2005 | 03:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Rim Blow Switch
Yeah, they are a devil to install. You have to remove the wheel to handle this job without the back pressure of the steering gear as you work around the wheel. You need to be sure the groove in the wheel is clean—scrape it with something to be sure, then clean it with a solvent safe for plastics. Then, apply lots of petroleum jelly! Some on the switch, some in the groove. Slightly arch the switch as you put one edge in, to get the other edge into the wheel slot. Never use any pointed instrument. Instead, make a tool out of wood about three-quarters of an inch long, slightly more narrow than the groove and with a rounded tip. With this tool, you can press the switch into the groove as you work around the wheel. Never stretch or pull the switch! This can cause the contacts inside to break through the insulation and short, thus blowing the horn all the time.
With the wheel out, you can compress the switch with your rounded tool (just as your fingers do when you blow the horn). Probably best to measure and begin the insertion at the middle, working around to each end, back and forth. This should do it.
Old Jan 14, 2005 | 08:19 PM
mach12004's Avatar
mach12004
Thanks for the info. I have to get the trunk floor job done before dealing with the wheel. HSB
lincolnshibuya
Jul 5, 2020 03:05 AM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
Sixer4Life
Sep 29, 2015 07:03 PM
