c4 trans ?
Old Jul 1, 2007 | 06:11 PM
eep4life's Avatar
eep4life
Default c4 trans ?
this is going to sound real stupid but how much trans fluid do you put in a c4 auto. trans
Old Jul 1, 2007 | 08:35 PM
66GTKFB's Avatar
66GTKFB
Default RE: c4 trans ?
Off hand, I would say to make sure it's at least to the minimum mark on the dipstick. If you are starting from scratch, for a 66 it's 7 3/4 quarts for the I6 version, 8 3/4 for a 289. Now check the dip stick. Any more, I wouild look for a puddle, any less, you may still have some in the torque converter.
Jim
Old Jul 1, 2007 | 09:00 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66GTKFB
Jim
Yeah, don't forget that the torque converter holds about 5 quarts and the tranny itself holds about 5 1/2. If you didn't drain the converter, then put in about 4 quarts and check it after you have run the engine and put it in gear. If it is still low, then add. You may want to spin the engine over until the drain on the torque converter is visible after the inspection plate has been taken off. If there is no drain on the converter, then that is another thread and a whole lot more explanation in how to get that old fluid out of the converter.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
97SN95GT
Sep 13, 2015 09:45 PM
