Backfiring??
Old Jul 13, 2007 | 08:36 AM
67 evil eleanor's Avatar
67 evil eleanor
Default RE: Backfiring??
If the exhaust thing does'nt work. Look at the distributor again and its advancement. Timing. One of two degrees can make a difference. The float lever needs to be set first. This should have been done anyway. Good luck.
Old Jul 13, 2007 | 09:27 AM
bluovalguy's Avatar
bluovalguy
ORIGINAL: 67 evil eleanor
yeah, I guess I just bought into the "Preset" theory. Lesson learned. So I will do that and then screw with the timing. I will start low and work my way up till it settles in.
Old Jul 13, 2007 | 10:11 AM
67 evil eleanor
I feel your pain, I have chased cats for about two weeks with an timing issue. Popping thru the exhaust at idle. Aftermessing with the A/F's, I finally adjusted the timing in the ECM at idle, and it now purs like a kitten. ManwasIdumb.I also have bought into the preset theory, on the floats, haven't found one to be right yet. Let us know what solves this, asit helps us all learn.
Old Jul 18, 2007 | 01:26 PM
bluovalguy's Avatar
bluovalguy
The floats were correct. I used a drill bit to measure, and they are right on the money. In about an hour I am taking back to the shop that did the exhaust and have them check it. Since I posted the last time, I have also changed out the gasket between the collector and reducer. It was not in that bad of shape, and there is not any rust on the headers or other exhaust parts. I thought there was. So we will see what the shop says about it.
Old Jul 18, 2007 | 02:03 PM
jlg2002's Avatar
jlg2002
if you still have air injection, its a classic case of a bad diverter valve. (allows fresh air into the exhaust manifold during decel if bad).
Old Jul 18, 2007 | 03:30 PM
bluovalguy's Avatar
bluovalguy
Just got back from the shop, no leak. So I have no clue. Also, the mechanic told me that maybe my valves may just have carbon on them, and maybe that could cause backfire. He said that he dumped a little water into the carb to burn it off??? Is that one of those little tricks of the trade that I am just to green to know? He also said tranny fluid would do the same thing if dumped into the carb.
Old Jul 18, 2007 | 04:34 PM
mat11089's Avatar
mat11089
I wouldnt put water in the carb.But the thing with tranny fluid is a just a cap full or so in with the oil and let it burn everything off then drain the oil.
Old Jul 18, 2007 | 04:46 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: bluovalguy
Yeah, misting water into the venturi of the carb will burn off all the carbon deposits that have collected on top of your pistons and your valves. That mechanic sounds like he knows his stuff regarding old carbureted engines.
Old Jul 18, 2007 | 05:10 PM
bluovalguy's Avatar
bluovalguy
He seemed to. I was a little leary at first, so I drove it about 15 miles afterward, both city and highway, and I didnt notice any negative effects (nor any real positive ones either). But it did not cure the backfire[:@][:@]
Sean
Aug 15, 2004 03:50 PM
Disgustang
Jul 27, 2004 09:43 AM
Obsol3te
Jul 26, 2004 08:42 PM
spuckie
Nov 21, 2003 05:51 PM
tchamber
Nov 9, 2003 05:47 AM
