anyone know?
Old Jul 4, 2007 | 03:33 AM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: anyone know?
it should pull out **** and shaft as one.. hold the button down as you pull it out.
cant remember with the 69 bezel. jim will probably know
Old Jul 4, 2007 | 04:10 AM
atomsk680's Avatar
atomsk680
ORIGINAL: Aussie66Fastback
i tried pushing the button and pulling the **** and it doesnt do anything. this wouldnt be a problem if painless just ad connectors on that pluged into the old wire connector harness. they gave me connectors that would plug into the old connector, but i dont know how to crimp the new wire with the connector[>:]
Old Jul 4, 2007 | 04:17 AM
Aussie66Fastback
to turn our lights on you pull **** out (no dick joke intended) rather than twist?
If yes, pull it to the fullest "on" position then try depressing the button and pulling some more while holding that button down. it should come out.
Old Jul 4, 2007 | 04:42 AM
atomsk680's Avatar
atomsk680
ok i just got it out, i had to pull the **** out allt he way then twist to the fulles on position, then i pulled and it cam out, now the switch and bezel are still in, and neither seem to want to come out
Old Jul 4, 2007 | 05:24 AM
atomsk680's Avatar
atomsk680
well i finally got the switch out, wired it up, put it back on, its just now the **** and rod arnt going in all the way. now to move over to the wiper switch[&:]
Old Jul 4, 2007 | 10:06 AM
hity645's Avatar
hity645
Sawzall works wonders in situations like this...and it gives you an excuse to buy a new one. Plus, to save on shipping you can buy other "essentials".
Old Jul 4, 2007 | 10:50 AM
73 Sportroof's Avatar
73 Sportroof
The wiper switch is an a d shaped shaft. Just give it a good pull. The **** is metal so it won't break.
[IMG]local://upfiles/70187/913B6A7C21C74E7A8D3E464B87E5FFAE.jpg[/IMG]
[IMG]local://upfiles/70187/926BCE16877E4DCAABB661F639E06A07.jpg[/IMG]
Old Jul 4, 2007 | 10:54 AM
73 Sportroof
On the light switch, when you put it back in make sure it is in the dome light position and you may have to push the button to get it all the way on.
