START COIL GETTEN HOT!!
Old Jul 4, 2007 | 05:52 AM
towins's Avatar
towins
Default START COIL GETTEN HOT!!
ok when i crank the motor over in my 67 302, the coil's terminal from the battery gets hot and some times smokes, also when i move the + wire from the bat the coil terminal (guts) mover and a pinging noise is made over in a box near the horn... any ideas??
Old Jul 4, 2007 | 11:50 AM
DonA's Avatar
DonA
Default RE: START COIL GETTEN HOT!!
You don't give very much info here. You also don't say if the engine starts or not. You also don't even say if it cranks or not.
If it does not crank I suspect that you have the two small wires at the starter relay switched.
If that doesnt work send me an e-mail with a complete description of what's going on and I will try to help.
dga1028@gmail.com
Old Jul 5, 2007 | 12:34 AM
mat11089's Avatar
mat11089
Keep posting on this so that if other members have smiliar problems they can all learn from your problem..Dont make it a private issue
Old Jul 5, 2007 | 05:54 AM
towins's Avatar
towins
the motor has just been put back in.. its just been recon, and yes it cranks.. but im only trying to turn it over not ready to start it yet, every thing seems to work wright sept for the smoke and the terminal getting hot... and wen its not doing any thing the wen you mover the terminal the guts of the coil move and, wat i think is a contact pings near the horn..
Old Jul 5, 2007 | 01:52 PM
66GTKFB's Avatar
66GTKFB
In the start mode, you are putting 12VDC into the coil direct. In the running mode, the voltage is reduced to 6 to 8 volts and that's what the coil is rated at. If you are simply turning the engine over to get oil pressure or a sanity check, disconnect the lead at the solenoid to the coil then crank it over.
Jim
Old Jul 5, 2007 | 04:01 PM
JMD's Avatar
JMD
Is the "coil" that you are talking about actually the starter solenoid? The soleniod will be on the passenger fenderwell. If so, it sounds like the connections to the solenoid are either loose, the cable ends are bad, or the solenoid is broken internally.
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
StalkerGT
Sep 25, 2015 02:41 PM
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
