351C Timing Cover Gaskets
Old Jul 6, 2007 | 11:00 AM
dozierstang's Avatar
dozierstang
Default 351C Timing Cover Gaskets
Hey, I was freshening up my 351C in my 69 (changing water pump, fuel pump, timing cover gaskets, valve cover gaskets, etc.) Anyways, I had to change the crank seal cause it was leaking. Is there a trick to putting the timing cover back on? I have tried to dry fit it but that bottom seal (oil pan seal) always gets in the way and the alignment studs don't match up. What am I doing wrong?
Old Jul 6, 2007 | 12:22 PM
atomsk680's Avatar
atomsk680
Default RE: 351C Timing Cover Gaskets
i have tried every possible way to get that on without removing the oil pan, i can safely say that you have to remove the cross member and remove the pan to get it on
Old Jul 6, 2007 | 12:24 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
and it will be a good time to add a new oil pump to boot a high volume one since cleves need extra oil volume
mirandaandjimmy
Nov 16, 2015 08:51 AM
waid302
Sep 14, 2015 11:19 AM
S'PortMustang69
Aug 30, 2015 08:27 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
