Which Spark plugs work well?
Old Jul 8, 2007 | 06:19 PM
colostang's Avatar
colostang
Default Which Spark plugs work well?
I am going to put new plugs in when a calibrate my carb next weekend and I was wondering if anyone has a "great" plug that works well and is cost effective. I have a 289 with an Edelbrock 600cfm, performer 289 intake, mild cam, hipo exhaust manifold and pertronix ignition.
Old Jul 8, 2007 | 06:26 PM
my77stang's Avatar
my77stang
Default RE: Which Spark plugs work well?
after going with platnum, double platnum, superduper quintuple platnum - i realized that standard copper core autolites work better than all of em. talk to a few local shops, they will tell you autolites beat out bosch, ac delco, ngk, or anyone elses plugs
i was surprised at the answer, but hey - these plugs are cheap so its a win win situation!
Old Jul 8, 2007 | 06:29 PM
02BlueKnight88's Avatar
02BlueKnight88
Shane is right. Original plugs are Autolite (Motorcraft) B-42, but since you have a liitle more oomph than stock you would want to use the liitle hotter plug. B-45.
Old Jul 8, 2007 | 06:33 PM
Soaring's Avatar
Soaring
I ♥ Acer
02BlueKnight88 is my nephew ya'll. Looks like he has learned his lesson well from his old uncle. B-45's it is.
Old Jul 8, 2007 | 06:52 PM
Colorado_Mustang's Avatar
Colorado_Mustang
I run 45's.
Old Jul 8, 2007 | 06:55 PM
atomsk680's Avatar
atomsk680
autolites
Old Jul 8, 2007 | 06:58 PM
Hornblower's Avatar
Hornblower
I ♥ Acer
I run B-45's too. You are wasting your money on anything more expensive unless you have a race engine, which you don't.
Old Jul 8, 2007 | 07:01 PM
66GTKFB's Avatar
66GTKFB
- It's whatever works for you but on other cars, specifically aVW 2180cc engines, a colder plug worked better. Keep in mind, the VW isa 133 CID 4 cylinder, air cooled, aluminum block (case), 11.0:1 compression ratio, a pair of 48 IDA Webbers. Not a normal engine.
-The plugs that I've had little sucess using on Fords have been Champion, NGK and Bosch. AC plugs worked fairly well, but I'll stick with Autolite or Motorcraft.
Jim
Old Jul 8, 2007 | 07:06 PM
Hornblower's Avatar
Hornblower
I ♥ Acer
I am not sure why Champions are reltated to GM engines, but that's what I remember the bow tie factories putting in them. The aftermarket NKG or what ever may be good for certain applications, but I have found that for my application with a fairly hot Ford engine that the B-45's are just perfect. For some reason, theheat range is just right. I guess if I toned it down some, the 42's would be more in line to use.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
movielover40
Aug 27, 2015 10:13 PM
overnight89
Aug 22, 2015 09:02 PM
microgt
Aug 20, 2015 07:12 AM
