short headers or no??
Old Jul 9, 2007 | 03:14 PM
quinchem's Avatar
quinchem
Default short headers or no??
As I'm looing around for headers it seems there are 2 types. Standard (I guess) and the shorties. Is there an advantage to either? I don't care except for ease of installation and getting replacement parts. I've included a link to a set I may be interested in....or should I go for the shorties??
http://cgi.ebay.com/ebaymotors/65-66...30070573QQrdZ1
Thanx
Old Jul 9, 2007 | 03:47 PM
highhilleer's Avatar
highhilleer
Default RE: short headers or no??
There are for types
Stock cast iron
Tri-Y used with early shelby's (like the ones in your link)
Shorties and
Long tube.
There are several manufactures of each and quality and fit varies quite a bit.
If you're going for all out performance, long tubes are the way to go. IMHO either tri-y or shorties are fine for a street driver and give you more room under the car for clearing speed bumps. There are a lot of opinions on proper header selection, so let the fun begin.
By the way - do not expect the chrome to look good for very long. Some headers tend to warp and pull away from the block resulting in exhaust leaks and a need to retorque the bolts. The key is to find a header with a thick flange. Since the ebay seller doesn't mention flange thickness, you might ask and compare to the specs for a quality header.
Good luck
Old Jul 10, 2007 | 05:17 AM
andrewmp6's Avatar
andrewmp6
save your money and buy a good pair them on ebay look like crap.the chrome plating wont stay on long.highhilleer is right get a set of tri y ones youll love them.
Old Jul 10, 2007 | 07:28 AM
Norm Peterson's Avatar
Norm Peterson
Headers are not the sort of thing that you plan on replacing pieces of, other than the reducers and the various gaskets, which are standard parts anyway. When the tubes go, it's probably time to replace the rest of the exhaust system, especially if there's been much winter-weather driving involved.
I guess the "ease of installation" requirement removes a fifth header type from consideration (180° crossover).
Norm
Old Jul 10, 2007 | 10:38 AM
jspagna1's Avatar
jspagna1
Go with Tri-Y headers. No fitment problems. My only suggestion is that you go with ceramic coated headers. Chrome ones, won't be chrome for long.
[/align]
Old Jul 10, 2007 | 02:12 PM
urban_cowboy's Avatar
urban_cowboy
I have equalength headers on my Bronco and love them. They are easy to install and do not hurt low end torque. They are also ceramic coated, so they will last forever. I have regular steel full length headers on my '69 Mach 1. I did not have a choice on what I got due to the restrictions on size and clearance. There is only one model and manufacturer of header that will fit a '69 Mach 1 351C 4V with PS and 4MT. I also do not like how low they hang. I do hit things with them from time to time. They sound great and perform great, but will not last as long as the ceramic coated ones and do create ground clearance problems. I bet I do not have more than 5 inches of ground clearance....I will measure this afternoon.
Old Jul 10, 2007 | 02:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yep, Urbancowboy's headers are rusty due to them being steel, and they barely fit with his 351C in his 69. I believe I would opt for the tri-y's too if they will fit. Ceramic coating costs a ton of money, but worth it over the long haul.
Old Jul 10, 2007 | 02:49 PM
urban_cowboy
Yeh. You generation 1 mustang guys have more options than the 69-70 folks do. Wish I could find a Tri Y or shorty that would fit, but no such luck. I just take want I can get.
Old Jul 13, 2007 | 09:09 AM
quinchem's Avatar
quinchem
Thanx for the advice. I'll go with the tri-Y ceramic coated...any particular brand orplace I should look for them?
Old Jul 13, 2007 | 10:12 AM
gothand's Avatar
gothand
My experience is that you absolutely cannot go wrong with JBA headers for your early Mustang. Granted you'll pay more, but they will fit, last, look good and perform.
http://products.jbaheaders.com/featu...mustangnew.asp
I haven't used their tri-ys but have had excellent results with the shortys in two different vehicles.
Good luck!
