charging trouble?
Old Jul 9, 2007 | 04:59 PM
nabontra's Avatar
nabontra
Default charging trouble?
So about 2 weeks ago I pulled the exhaust manifold on my 66 coupe (200cid) and put a new gasket on, since the original was basically destroyed. It sounds quite a bit better, but about a week ago my belts started squealing when i accelerate. I checked the belts, they didn't seem worn or cracked so i treated them with a can of belt conditioner i had in the garage. It helped, but theres still a slight squeak. And today i noticed that on my amperage gauge on the dash, the needle used to be dead center between "D" and "C", but now is about a 1/4" towards "C". Thinking it wasn't putting out the proper voltage, i had the alternator checked at the parts store down the street. according to them its putting out the proper voltage/amperage and my battery is good.
Should i ignore this newfound gauge reading? Chances are I will replace the belts anyway, since i can't remember when i last did it.
Thanks for any advice!
Old Jul 9, 2007 | 05:12 PM
66GTKFB's Avatar
66GTKFB
Default RE: charging trouble?
If you have a voltmeter, check the voltage to ground with the engine off, then do it again with the engine on and maybe a little above idle - like rev it a bit. The first reading should be between 11.5 and 12.5 volts, the second between 14 and 18 volts. If you got that, you're ok.
Jim
Old Jul 9, 2007 | 05:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66GTKFB
Jim
But if not, then you need to replace your belts with new ones and tension them correctly. The pulley channels may need a good cleaning as well.
Old Jul 13, 2007 | 03:25 AM
nabontra's Avatar
nabontra
ha, found the root of the problem. checked it with the multimeter and the reading was fine, my a/c pulley was locking up and causing the belt to drag. i just picked up a shorter belt and all is well! thanks!
Old Jul 13, 2007 | 03:32 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: nabontra
Case closed.
CS2007
Jun 25, 2019 09:45 PM
bradleyb
Nov 27, 2015 07:50 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
ChampInSD
Oct 2, 2015 04:55 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
