1966 Rear Question...?
Old Jul 10, 2007 | 03:23 PM
takeoutexodus's Avatar
takeoutexodus
Default 1966 Rear Question...?
Did the 1966's V-8's come with factory disk brakes
Power steering etc.?
Old Jul 10, 2007 | 03:50 PM
groho's Avatar
groho
Default RE: 1966 Rear Question...?
I believe only front disc brakes were an option, and only on GT's or better, butpower steering was available on all models.
Old Jul 10, 2007 | 03:53 PM
takeoutexodus
thanks ,
hmm .. i wonder if i can find some on a junker.
Old Jul 10, 2007 | 04:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
Good luck finding a junker that isn't a pile of rusty nuts and bolts.
Old Jul 10, 2007 | 04:15 PM
groho's Avatar
groho
SSBC has a great set I put on my '66 for around $900. talk about a huge difference in stopping power!
The rear discsare a little less, but Ipurchased areally good pair of porterfield brake shoes that work great with the rear drums. I saw a used set of original discs plus calipers,running at $300, but I'd question the thickness (and measure it yourself) before buying a used set.
Everyone is aware of the Granada swap, and charge for it, then never both to mention you needtie rod endsand sleeves to make itfit.For the money, you're probably better off buying new. There is a company back east. . .brakemaster???but he admitted they were generic GM brakes, discs and calipers for about $750.
The SSBCs are correct, and when replacing parts, it's same as the factory fordparts, and you can get parts from anylocal parts house, in other words, "I need front pads for a '66 mustang", not a'68 nova.
Old Jul 10, 2007 | 04:23 PM
66GTKFB's Avatar
66GTKFB
Disc brake were a stand alone option for 64 to 66 Musangs V-8 cars. They were included in the GT option. If you buy a used set, be prepared to shell out between $400 and $600 for new and rebuilt parts; calipers, rotors, hoses, master cylinder, proportioning valve, etc. They will not be power assisted. You would be better off paying for a disc brake kit at $1000.
Jim
Soaring's Avatar
Soaring
I ♥ Acer
Dennis Ginsberg, a member on here, has a Granada swap kit that is all new parts for under 600 bux. Give him a call or email him to find out all the details.
http://www.discbrakeswap.com/The_Gra...9.3006.v01.pdf
Old Jul 10, 2007 | 05:54 PM
Tony R's Avatar
Tony R
Soaring. I tried to type in the discbrakeswap web page in the ad that you posted for Dennis Ginsberg. You have posted that before but I have never been able to find his site for prices. I have always gotten a search engine for brakes. Is his site current or do you have another way of contacting him? I looked all through that site you posted and didn't see any other way of contacting him.
baddog671
Jul 26, 2016 01:20 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
