Ground Effects
Old Jul 10, 2007 | 11:33 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: Ground Effects
Old Jul 11, 2007 | 12:21 AM
mat11089's Avatar
mat11089
Itll work.My hood scoop is molded and hasnt cracked on the sides..Now the front where it gets wind resistance is another story.
Old Jul 11, 2007 | 12:49 AM
andrewmp6's Avatar
andrewmp6
depends how big the gap is your tring to fill in you might have to use sheets of fiberglass then kitty hair over it. then the normal painting prep. see if you can find a how to use fiberglass book. i believe theres one on kit cars showing you have to fix and repair the fiberglass that got messed up making/shiping it.i molded in the rear fender flares on my dually with sheets of fiberglass its been 5 years no cracks yet.
Old Jul 11, 2007 | 01:39 AM
Shifty101Easy
ORIGINAL: 66GTKFB
Sex appeal for low riders. You learn all the bumps and dips in your town. All the rail road crossings, speed bumps, crooked drive ways into fast food restaurants, pot holes, road kill (very dangerous - you go first), etc. There is a cure - a pair of Tommy Lift rams.
Jim
it goes no lower than the current rocker panels...its just like...an "edge"...
Old Jul 11, 2007 | 06:29 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: Shifty101Easy
ORIGINAL: rmodel65
my flare are molded as well as my rear spoiler yes it will eventually crack but im ok with that what i did was laid mat down then glassed the flare on let it dry featheres it out glassed the top feathered it out then smooth with filler but id look in to some panel bonding adhesive and id fiberglass over top of it to mold it all in
do you have any pics of that perhaps?
sorry i dont have any pics of the work in progress not digital anyways but ive got some of the finished product and i can walk you through step by step if you would like
Old Jul 11, 2007 | 06:54 PM
6marc5's Avatar
6marc5
Hello,if you have a boat manufacturing plant or a marine store near you,you might be able to buy some flex putty. This is a bondo type adhesive that retains it's flexability. Don't forget to p/u some catalyst too. this is what we used at sea ray boats to spot putty the stringers and sub floors ect in place with.
Old Jul 11, 2007 | 07:07 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
heres adhesive to bond the metal to the glass parts then all you would need to do is rough up th esurface bond them let cure completely then lay mat out and glass it all smooth then use filler to smooth it all out https://www.autobodytoolmart.com/p-11231-13701.aspx
Old Jul 11, 2007 | 09:55 PM
Shifty101Easy
ORIGINAL: rmodel65
the more i think about it the more im kind of shying away of yet another time consuming body work job before paint...i think i might just bolt em on and let em be...im prob going to go with a darker color so it should help hide the line better...and it really wouldnt look bad anyways just thought the molded was cool and sleek looking....
as for the adhesive...i need to bond my GT/CS side scoops on....i ordered some adhesive i the past but it didnt show up with my order and was later notified they were all out of it...
that should work for my scoops right?
would you paint underneath the scoops or just leave it primer, glue the scoops on and paint as one piece?
Old Jul 12, 2007 | 09:22 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
definitely need to paint under there otherwise its gonna rust primer is absorbs water just like filler does its a little different when dealing with expoy primers that have better corrision resistance but id do it to definitely be on the safe side
Old Jul 13, 2007 | 02:57 AM
andrewmp6's Avatar
andrewmp6
rmodel is right paint under them glue them on then paint them. you still gonna use that ground effects kit im still thinking of making mine a exp 500 clone but just looks like it not a true clone.
