fuel pump ?
Old Jul 12, 2007 | 03:55 PM
eep4life's Avatar
eep4life
Default fuel pump ?
ok so im running a weiand 174 blower (pretty much) and a holley 750 cm 4 barl. dlb pump carb what psi rating should my feul pump be at....
Old Jul 12, 2007 | 06:21 PM
easttennmotors's Avatar
easttennmotors
Default RE: fuel pump ?
most pumps operate at 9-14 psi, If you are looking for an awesome pump, I use weldon fuel pumps. best out there imo, expensive but well worth it. easttennmotors.com
Old Jul 12, 2007 | 07:32 PM
gothand's Avatar
gothand
Most of the mechanical pumps listed on Summit are in the 6-8 psi range. Anything above that and you're going to have to add a regulator. Blower or not, I can't imagine your Holley carb wants to see any different pressures than the 5 to 7-1/2 psi specified in the manual.
I've never added a supercharger and admittedly know very little about them, but I do know that Holley sells carbs designed for use with roots style superchargers.
Old Jul 12, 2007 | 08:19 PM
Colorado_Mustang's Avatar
Colorado_Mustang
You really need to know the fuel flow of the pump, not necessarily the pressure. The Holley carb will only handle 5-7 psi itself, and will handle quite a bit of flow.
Read this.
Old Jul 13, 2007 | 07:09 AM
andrewmp6's Avatar
andrewmp6
the blower hes using is a 671 a small roots as long as the carb isnt to small for the engine cfm is not a problem.colorad is right its not your psi is your flow rate gallons pre hour.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
