reverse light problems
Old Jul 13, 2007 | 12:35 AM
1sick66's Avatar
1sick66
Default reverse light problems
I am trying to get my reverse lights working, i tested the wiring and lights they work fine. Does anyone know if there is a switch or something that could be shorted or blown.
Old Jul 13, 2007 | 12:41 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: reverse light problems
Yeah, you have a switch near the tail end of your transmission, that when you put the car in reverse, it triggers that switch. They are expensive little boogers.
Old Jul 13, 2007 | 06:00 AM
palerider's Avatar
palerider
Called neutral safety switch - assume you have an auto. Depending on year you can get at atutozone - all mustng suppliers carry them
Old Jul 13, 2007 | 04:48 PM
jlg2002's Avatar
jlg2002
ORIGINAL: palerider
Soaring's right if you have a manual, Paleriders right if you have an automatic. Regardless, to check if it's your switch, disconnect the plug at your firewall (near the left underhood brace) and jumper it (firewall side not the plug). With the ignition on,and thelights come on, the problem is with the switch, if not, its in the rest of the circuit.
Old Jul 13, 2007 | 05:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: jlg2002
ORIGINAL: palerider
OH, I thought all real men Mustangers drove manual transmissions. I thought automatics were for women.
Old Jul 13, 2007 | 06:34 PM
66GTKFB's Avatar
66GTKFB
My 66 GT K code Fastback is an automatic C4, same as a GT350H. When you punch it, you don't know when it's going to shift - but when it do - it DO.
Jim
djbigskrilla
Sep 20, 2022 01:04 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
movielover40
Aug 27, 2015 03:26 PM
jjwinel78
Aug 17, 2015 03:34 PM
philster0306
Aug 10, 2015 11:33 AM
