One wire alternators?
Old Jul 13, 2007 | 03:32 PM
cpartridge's Avatar
cpartridge
Default One wire alternators?
Anyone had any experience with converting to a one wire, internaly regulated alternator? The conversion sounds really easy but is it a good idea? Also, any preference as to brand of alternator?
Old Jul 13, 2007 | 03:50 PM
67mustang302's Avatar
67mustang302
Default RE: One wire alternators?
I'm running a Powermaster 140a. just hook it up the way it says, and then what I did was tape off the wires individuallythat went to the factory alt, and unplugged the factory voltage regulator. Works great
Old Jul 13, 2007 | 03:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
It's an easy way to get a lot of amperage, and to get rid of a lot of old wiring.
Old Jul 13, 2007 | 04:05 PM
19stang66's Avatar
19stang66
Mine will be great once I get the damn thing working properly!!
http://store.summitracing.com/partde...p;autoview=sku
Old Jul 13, 2007 | 05:16 PM
LCC's Avatar
LCC
Mine is a Powermaster. When you buy one, buy new. I went through two rebuilt ones before I got one to work. I put that one in the corner and stepped up 100amp new Powermaster, first one worked perfect, and still works....
Old Jul 13, 2007 | 05:21 PM
JamesW's Avatar
JamesW
The only thing you'll notice different with a 1 wire alternator is that it doesn't energize it's charging circuitry until it's revved to 2K rpms once. So after you start it..you have to 'kick it' once.
Old Jul 13, 2007 | 05:46 PM
19stang66's Avatar
19stang66
hmmm i didn't know that James. Thanks for the heads up.
Old Jul 13, 2007 | 08:00 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
ORIGINAL: JamesW
isn't the term for that self exciting
Old Jul 13, 2007 | 08:29 PM
JamesW's Avatar
JamesW
yeah!..that's it!
Old Jul 13, 2007 | 08:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
Self exciting is the term they use, but self exciting has absolulely nothing to do with the circuitry. Basically, self exciting has to do with the single wire bypass of the VR.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
