Would you fix this or replace this?
Old Jul 13, 2007 | 08:45 AM
Stevetra's Avatar
Stevetra
Default Would you fix this or replace this?
Here is a picture of the outer rocker sheet metal on my car
Would you cut it our, reform it and then put it back...
Or would you buy a repop piece for $90 and weld it in.
Old Jul 13, 2007 | 08:47 AM
eholzer07's Avatar
eholzer07
Default RE: Would you fix this or replace this?
depends on you expirience and money to you have to spend. If your on a tight budget (like me) I would go ahead and try and do a fixe on it. It is a fairly simple piece of metal. Get some scrap metal. put it up to the original panel you are repairing. bend it to similiar shape. Then cut it to fit. If you have the money and less expirience. Get the replacement
Old Jul 13, 2007 | 08:56 AM
67 evil eleanor's Avatar
67 evil eleanor
No doubt, replace it. This is a major part of the unibody and needs to be solid and straight.
Old Jul 13, 2007 | 10:42 AM
66GTKFB's Avatar
66GTKFB
Ifthis will work, get a reproduction, trim, weld it over the existing one and fill the gaps with Bondo or one of the door sill scuff plate add-ons. You keep the structural strength and get the 'virgin' look.
Jim
Old Jul 13, 2007 | 10:53 AM
Stevetra's Avatar
Stevetra
I was of the understanding that the inner rocker was the structural part, and what is all bent up is the outer rocker skin. is this not true?
Old Jul 13, 2007 | 11:42 AM
66GTKFB's Avatar
66GTKFB
I took a quick look at the Weld and Sealant Manual and it looks to be a structural member not a trim piece, at least it's got a lot of welds.
Jim
Old Jul 13, 2007 | 11:56 AM
Stevetra's Avatar
Stevetra
very well then...replace it is.....sigh...
Old Jul 13, 2007 | 12:00 PM
gothand's Avatar
gothand
If it is covered by a rocker panel moulding, why not just fill the holes, repaint and install the mouldings again? I am assuming that it is only flaking paint at the pinch weld towards the left of the picture. Am I missing something?
Old Jul 13, 2007 | 12:01 PM
66GTKFB's Avatar
66GTKFB
It looks like it was involved in using a curb to slow down, the long score.
Jim
Old Jul 13, 2007 | 01:10 PM
JMD's Avatar
JMD
It is hard to say what I actuallywould do, because sometimes I change my mind once I get started with a repair, but considering all of the widespread damage, and the problems with the bottom seam, I think I would replace it. It would just be too hard to get that thing straight without taking the panel loose on the bottom, and at that point, a person would want to continue along and just replace it anyway...
I might not replace the whole part, but most of it for sure.
