Power steering
Old Jul 14, 2007 | 02:43 PM
sixtysix's Avatar
sixtysix
Default Power steering
I am in the middle of replacing my power steering pump and the two hoses coming off the back of pump to the control valve.I am having trouble putting the hose on the control valve-just cant get it to line up straight-dont want to cross thread the fitiing.
Here is the question-is it ok to drive the car without the hoses hooked up-I dont have the belt on the power steering pump either-or is this bad for the ram and control valve?
Thanks Scott
Old Jul 14, 2007 | 02:49 PM
66GTKFB's Avatar
66GTKFB
Default RE: Power steering
It's not a good idea, the ram shaft can get bent. Try this - remove that reluctant hose and attach it with the hose flopping free. If you have an interference problem with another hose, remove that. I hope you are using flare nut wrenches.
Jim
Old Jul 14, 2007 | 04:55 PM
sixtysix's Avatar
sixtysix
Thanks-Im using a 7/16 opened end box wrench to tighten the fittings scott
Old Jul 14, 2007 | 06:09 PM
66GTKFB's Avatar
66GTKFB
Go to Sears and get a flare nut wrench. Your knuckles will appreciate that and you won't make round nuts out of hex.
Jim
Old Jul 14, 2007 | 08:05 PM
66GT350man's Avatar
66GT350man
you can have my powersteering parts :-P i just hacked all the stuff off my 66 GT
Old Jul 14, 2007 | 10:09 PM
sixtysix's Avatar
sixtysix
Thanks-I could use the high pressure hose.I think I kinked mine.Thats all I need. Scott
send me your e mail address
Old Jul 14, 2007 | 10:35 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66GTKFB
Jim
Nah, just call Snap-on and they will deliver the correct flare nut wrench right to your shop. But, you first have to give up your first born to them.
Old Jul 15, 2007 | 01:14 AM
gothand's Avatar
gothand
ORIGINAL: Soaring
You're not kidding. In '99, I paid $17 for a single security T40 socket for my Jeep.
Old Jul 15, 2007 | 11:53 AM
66GTKFB's Avatar
66GTKFB
Snap-On has good tools but expensive (duh). There are some tools in their line that are not available anywhere else - yet (Harbor Freight), so mine are mostly Craftsman (grandfather worked for Sears).
Jim
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
