Differential advice?
Old Jul 16, 2007 | 09:26 PM
baddog671's Avatar
baddog671
Default RE: Differential advice?
ORIGINAL: 66GTKFB
Replace the housing or replace the gearing. You need to be a LOT more specific.
Jim
- 9" Housing/Axle Package (67 Mustang)
- Moser Axles, Axle Bearings, Wheel Studs, & Retainers
- 31 Spline, 5 on 4-1/2" Bolt Pattern, 1/2" Studs
- Center Section (Assembled)
- New 31 Spline Trac-Lock Posi
- New Motive Performance Gears (3.70)
- New Timken USA Bearings
- 11" Disc Brake Kit w/ Parking Brake
This would be a complete 31 spline setup with your choice of gear ratio. We use new Moser axles (not factory re-splines). We also use new trac-lock posi units, not torque-lock units (modified open carrier).
This center section would be good up to 500HP. If you plan on having more than that you will want to go to an aftermarket setup. It would be $1125 instead of $820 for a complete center with the Strange Nodular Iron S-Case, Aluminum or Iron Daytona Pinion Support, 1350 Steel Yoke, Motive Performance Gears, 31 Spline Trac-Lock Posi, & Timken (USA) Bearings. ALL NEW & ASSEMBLED!
Old Jul 16, 2007 | 11:04 PM
Aussie66Fastback's Avatar
Aussie66Fastback
ORIGINAL: fast66
ORIGINAL: Aussie66Fastback
I would take the true trac every day of the week and twice on Sundays. I cant speak for US prices but over here its line ball between true trac and trac lock in terms of cost and the true trac slaughters trac lock for performance and durability.
PM Gunjam - he just fitted one.
Aussie66, are you running a true trac? Im looking for one to fit to my 8" but haven't had much luck here in Aus. I've done some digging on the powertrak, but can't get on to any distributors.
I dont have one in the Stang yet, but we run one in this beast (pic) and it gets punished HARD. I put a new trac lock in the stang just before I discovered the truetrac. It is crap in comparison, but i will be a little while before I can justify the $ to do the stang...it will be done as soon as I can afford it. They are so seamless to drive on you dont even know they are there.
fast66 try Rocket Industries (02 8825 1900)
[IMG]local://upfiles/48146/D31C5795EF8F40C290965B2F62F1489A.jpg[/IMG]
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
