best engine/radiator flush
Old Jul 16, 2007 | 12:18 AM
az1966's Avatar
az1966
Default best engine/radiator flush
need to replace my radiator, seems like it's coming apart after 2 years,,, when I pulled the head to rebuild it ,,,, the block had what looked like massive rust build up in the water passages, I've heard that oxalic acid is best to flush the sytem and then use baking soda to nuteral ize....problem is I can't find it any where so what would be the next best thing to use for a solid flush?
200 ci 6 popper, 3 spd manual, 3 row radiator 1 bbl carb
Old Jul 16, 2007 | 12:27 AM
Sean W.'s Avatar
Sean W.
Default RE: best engine/radiator flush
[sm=icon_rofl.gif]1 bbl carb!
Old Jul 16, 2007 | 12:33 AM
az1966's Avatar
az1966
yeah I'm trying to keep it stock like the day it came off the assbly line
Old Jul 16, 2007 | 01:04 AM
Aussie66Fastback's Avatar
Aussie66Fastback
I've tried various commercial radiator cleaner/flushes with pretty limited success.Dipping a disassembled block seems to be the only thing that works properly.
I suggest you fit a Tefba filter (or Gano or sock)to the top radiator hose regardless of how successful you think the flush is... for a few months you will be pulling chunks of crap out of it, but it will gradually clear to the point you dont need it at all.
Old Jul 16, 2007 | 02:16 AM
Soaring's Avatar
Soaring
I ♥ Acer
Plain water is the only flush you should ever use.
Old Jul 16, 2007 | 12:42 PM
shikoz's Avatar
shikoz
I heard that flushing is illegal unless performed by a technician at a licensed shop with the proper certificates to do such work. Also, I thought that certain types of reclaiming devices are supposed to be used so that it's properly disposed of. ehh . . . maybe only here in California.
Old Jul 16, 2007 | 02:16 PM
bodyputtyless's Avatar
bodyputtyless
You'll be sorry if you flush the system. You'll be tearing out the heater core after it springs a leak from the flushing. If the block is that clogged then you should remove the motor and tear it down. Have the block dipped,burned, whatever the local speed/machine shop recommends to eliminate the clogged water jackets. Then again, maybe the heater core in your model is an easy tear out. Its not so much fun in mine.
Old Jul 16, 2007 | 04:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: bodyputtyless
Yep Michael you are dead on about the heater core needing to be replaced IF he uses a radiator flush acid. Plain water will flush the system just fine, and it should be done once a year, and add new coolant. This is just common maintenance procedures.
Old Jul 16, 2007 | 06:07 PM
Aussie66Fastback
flushing with water is fine provided you have a maintained system to start with otherwise it justclears enough gunk to make you feel like you have achieved something (but really the problem is not solved).
in this case, its (a) pull motor down and start with new rad and heater core or its (b) trap the gunk in a filter. I know which one i'd be doing first
4cylinderplus2
Oct 9, 2020 07:45 PM
Nov 18, 2015 01:34 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 10, 2015 07:23 PM
laserace
Sep 2, 2015 07:55 AM
