Trunk Lock question
Old Jul 16, 2007 | 09:12 AM
VintageBlue's Avatar
VintageBlue
Default Trunk Lock question
got an easy one....do you need the key for the trunk lock to change out the trunk lock?
Old Jul 16, 2007 | 09:28 AM
shr's Avatar
shr
Default RE: Trunk Lock question
not on mine there is a big c-clip taht holds it in, pull that out and the outer lock pops out and dont loose the rod that goes from the lock to the latch though! but yes you will need keys to operate it
Old Jul 16, 2007 | 10:39 AM
66GTKFB's Avatar
66GTKFB
I assume you lost the key to your Honda - you didn't say what year or model either. You need to get the trunk open first. Then the lock can be removed.
Jim
Old Jul 16, 2007 | 03:10 PM
VintageBlue
ORIGINAL: 66GTKFB
Jim
I can see how I confused you considering I am in the Classic Mustang Forums....and I asked if you needed the key to remove the lock (like you need for the ignition), not if the trunk needed to be open to remove the lock.
Old Jul 16, 2007 | 04:11 PM
Soaring's Avatar
Soaring
I ♥ Acer
Even though you are in the Classic Mustang section, we don't know what car you have. Is it a coupe, fastback, sport roof or convertible? And, what year is the car? Secondly, did you lose the key to the trunk? No, you do not need the key to remove the lock if the trunk if open. If it is closed, then yes you need to get the trunk open to remove the lock. However, it is not like the ignition where you have to turn the lock to ACC. to get the lock out.
Old Jul 16, 2007 | 06:40 PM
66GTKFB's Avatar
66GTKFB
And different years used different ways of holding the lock in place.
Jim
Old Jul 16, 2007 | 09:18 PM
VintageBlue
ORIGINAL: Soaring
Thank you, that is all I was looking for.
Old Jul 16, 2007 | 09:44 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: VintageBlue
ORIGINAL: Soaring
Come back and visit again. Jeez, you would think with your attitude that we are a think tank and free information is offered here without your input.
JoshyGT
Sep 19, 2017 08:52 PM
Ipaman
Sep 22, 2015 07:01 AM
maestro1024
Sep 21, 2015 02:40 PM
pimp2303
Sep 17, 2015 08:45 PM
movielover40
Sep 15, 2015 10:37 AM
