351W
Old Jul 16, 2007 | 06:45 PM
nicholastuccio's Avatar
nicholastuccio
Default 351W
How hard will it be to put a 351W into a 67 coupe. What considerations are there. What do i need to keep in mind
Old Jul 16, 2007 | 06:48 PM
Sean W.'s Avatar
Sean W.
Default RE: 351W
im pretty sure its the same block as the 289, just different bore size, i think it will be pretty easy..
Old Jul 16, 2007 | 06:49 PM
dodgestang's Avatar
dodgestang
Default RE: 351W
No it is easy, just make sure you repair/replace/upgrade things like tranny, suspension, brakes, rear, and cooling system to match up to your power levels. If it was a v8 car originally and all you are putting in is a stockish 351w just make sure everything is in good working order. After that you can consider updates/upgrades as appropriate to meet your driving needs/performance goals.
Old Jul 16, 2007 | 06:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 351W
She'll slide right in, but with any transplant you will need to make some adjustments.
Old Jul 16, 2007 | 06:53 PM
66GTKFB's Avatar
66GTKFB
Default RE: 351W
Depends on what was in the 67 in the first place. The motor mounts are different and are not interchangeable with any other year.
Jim
Old Jul 16, 2007 | 06:54 PM
67coupe's Avatar
67coupe
Default RE: 351W
It does fit just fine, I have a 351W in my 67. It is a lot larger engine than a 302 or 289 though. You don't appreciate how much bigger until they are side by side on the garage floor.
Old Jul 16, 2007 | 07:00 PM
4reboy's Avatar
4reboy
Default RE: 351W
ORIGINAL: Sean W.
Nope. The 351 is like a 289/302, only with a taller deck (longer stroke), therefore making it taller AND wider . The wider is what is most concerned with when putting it into something pre 1969. With a 1967 it shouldn't be too much trouble at all, but spark plugs might prove a small challenge, but nothing like a 65/66.
Old Jul 16, 2007 | 08:03 PM
Rorin67's Avatar
Rorin67
Default RE: 351W
ORIGINAL: 4reboy
...but spark plugs might prove a small challenge, but nothing like a 65/66.
Not a problem at all - plenty of room. With a taller deck though, you need to be careful what intake manifold you use if you have a stock hood. If you get a tall intake manifold, then the air cleaner may hit the hood. Shelby-style hoods help here...
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
FoxGT
Jul 11, 2004 11:49 PM
Mustang88LXKid
Feb 29, 2004 08:01 PM
WNDSOR
Jan 30, 2004 09:47 AM
