Drive shaft installation question
Old Jul 17, 2007 | 11:57 AM
crey's Avatar
crey
Default Drive shaft installation question
Has anybody recently installed a driveshaft?
I'm having a problem installing mine. After tightening up the u-bolts on the differential yoke, the rear u-joint center has1/16" of play between thecaps on the yoke. I'm assuming the caps are held from flying out by the lip on theedge of the differential yoke. Myu-joints aretheinner snap ring type. The u-joint caps are held inside the driveshaft lugs by the snap-rings on the caps.The forward u-joint and rear u-joint in the driveshaft lugs are all nice and snug.
Are the inner snap-rings needed for the u-joint capsin the differential yoke as well? I put some in the first time I tried installing my driveshaft, but they seemed to be interferring with the differential yoke.
Old Jul 17, 2007 | 02:13 PM
jlg2002's Avatar
jlg2002
Default RE: Drive shaft installation question
Napa shows a 1" cap and a 1.125" cap u-joints for Mustangs. It sounds like you have the wrong u-joint installed.
Old Jul 17, 2007 | 03:56 PM
67SuperSnake's Avatar
67SuperSnake
+1 on the wrong U joint.
Old Jul 17, 2007 | 04:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
+2 on the wrong joint. Ya got the wrong one.
djbigskrilla
Sep 20, 2022 01:04 AM
Urambo Tauro
Sep 7, 2015 12:47 PM
kevans79@yahoo.com
Aug 18, 2015 09:01 PM
Boostaddict
Lethal Performance
Aug 13, 2015 01:57 PM
ccwebb
Aug 11, 2015 06:47 PM
