engine dying on 67 mustang
Old Jul 19, 2007 | 11:35 PM
kyles67's Avatar
kyles67
Default engine dying on 67 mustang
my car will start and after about 5 seconds it will just die.
the only time it will stay on is if i keep my foot on the gas.
and if i take my foot off the gas when im stopped at a red light or putting it in reverse, etc it will die.
do i need to change the throttle cable, does it have to do with my throttle at all?
any advice would help at all.
thank you
Old Jul 19, 2007 | 11:38 PM
66GTKFB's Avatar
66GTKFB
Default RE: engine dying on 67 mustang
We need the engine, carburetor and transmission types and when did this start?
Jim
Old Jul 19, 2007 | 11:47 PM
kyles67's Avatar
kyles67
67 mustang
engine - 71 302 2bbl
automatic
the car hasnt been started in over a yr
i just started it up yesterday
Old Jul 19, 2007 | 11:53 PM
66GTKFB's Avatar
66GTKFB
You probably have a carburetor that's plugged up with old gas. Get a couple of spray cans of Berryman's B-12carburetor cleaner, remove the carburetor and spray away. Clean the outside and spray some B-12 into to fuel inlet with the carb up side down then remove the top carefully and spray some more inside. Let the spray sit, it will loosen up the gunk. Be careful, it tastes like crap. Finally, spray some into the jets with the plastic extension. That may do it.
Jim
Old Jul 20, 2007 | 09:04 AM
Jakaru's Avatar
Jakaru
replace any fuel filters as well and check the fuel lines. Also replace the points on the distributer if you still have em.
Old Jul 20, 2007 | 09:12 AM
Soaring's Avatar
Soaring
I ♥ Acer
Drain that old gas and replace with a fresh tank full.
djbigskrilla
Sep 20, 2022 01:04 AM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Philhampton1
Aug 21, 2015 12:04 PM
daytooday
Aug 11, 2015 09:22 AM
