Nice Paintjob....
Old Jul 20, 2007 | 02:58 PM
Nabster's Avatar
Nabster
Default RE: Nice Paintjob....
When we had ours done, we had the body nearly completely disassembled, all sanded down, all the small dents repaired, a few patches done in the bottom of the rear fenders to fix the rusted through holes from water damage, then primed, painted in the new version of the original lime gold, and one coat of clearcoat. It was in the shop probably 4 months because we knew the guy in charge and cashed in a favor to get a nice discount on the work, it was done in the time the shop wasn't flooded with insurance claims, but it finally ended up costing us $3800, without the discount we got it would have been easily $5000.
Old Jul 20, 2007 | 03:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
A nice fully painted car does not mean a nice paint job. It means the whole car. Speak English. I had mine done 12 years ago, and it cost me 5 grand. The shop took off the doors, hood and trunk lid front and rear glass with chrome, sand blasted it, replaced a few rusty spots on the rear quarter and the bottom of the doors, prepped it and painted it. Now, that was 12 years ago and out in west Texas where things are generally cheaper than Kali orYankee land. I would expect my paint job to cost about 7 grand today. If it doesn't look like this before they paint it, they are not doing a quality job. This is Ol' Yeller before they took the glass out and replaced the headliner. The 1st shot is how she looks 12 years later. The paint job is one job you cannot skimp on.
Old Jul 20, 2007 | 04:09 PM
gothand's Avatar
gothand
ORIGINAL: Soaring
<snip>
You mean like this? First blasted >epoxy primed > ding repair > epoxy prime over that portion (yellow) > some sort of sanding prime > block sanding > maybe some other prime? and then paint. I don't know much about paint and body but so far so good.
Old Jul 20, 2007 | 04:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yep...You still have a ding on your rear quarter though. All of my running gear was left in place though. That saved a ton.
Old Jul 20, 2007 | 04:17 PM
66GTKFB's Avatar
66GTKFB
Jeff,
Do youself a favor, pull that plug on the end of the cowl and clean the cowl area out = and don't tell me you are goint to reuse the headliner.
And a note ot all 64 to 66 owners - see the opening in the sheet metal at the lower part of the cowl. That gets filled with leaves and keeps water in the cowl area.
Jim
Old Jul 20, 2007 | 04:18 PM
gothand's Avatar
gothand
Ha ha, that is dust from the shop, not a ding. Looking at the picture, I see I'll have to remind them to remove the door striker. The running gear is in mine as well as I've already painted the engine bay and put in a new driveline, however, the rest of the car is stripped to the bone. It certainly isn't a show quality restoration, I just wanted to make sure the paint itself is done to last.
[edit] You're right about the plug Jim, I meant to mention that as well. Oops. You are correct about the gunk at the outlet. Mine was filled with pine needles, but fortunately, the metal is all still good in there. I imagine different leaves would probably plug things up a lot more.
[2nd edit] You don't like my headliner Jim? It is the original factory one and I want to leave it original. Actually, it was glued in pretty well from the factory so I just left it and the blaster 'separated it from the body'. I have a new one that I'm going to install myself (wish me luck) after I reassemble the interior. Since the headliners are so cheap and it is completely empty, I'll give it a shot. If it comes out lousy I'll have a shop do it. The fact that the windows are out give me hope that I'll be able to pull it off. We'll see.
Old Jul 20, 2007 | 04:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, that headliner is right out of the "Beverley Hillbillies."
Old Jul 20, 2007 | 04:50 PM
66GTKFB's Avatar
66GTKFB
Rip all that headliner out, paint on some POR-15 and install a new sound deadener. As long as you are there -
Jim
Old Jul 20, 2007 | 05:20 PM
LCC's Avatar
LCC
ORIGINAL: JMD
The question is like asking everyone on the forum to step outside and report on the exact shade of the sky today, of course the shade would be different depending on where it is being viewed from, and of course everyone would have a different idea of what each shade should be called.
A "nice" paint job has different meanings for different people. Would your definition of a nice paint job include painting the door, hood, and trunk jambs? Would the nice paint job include painting the underside and /or inside of the car?
What is the condition of the body and current finish of the car? Have there been poor repairs done on the car in the past?
I think that if you are talking about a "sand and shoot" the prices given in previous posts are ballpark..
I agree......
The best way is to go to a few shops and get quotes. Don't pick the cheapest because that's their way of getting you in then upping the price with "incidentals". The good shops will give a price on the painting and leave the body on a pay as you go. That way you can decide how much or little you want to spend on the body work.
dcohen's Avatar
dcohen
hey gothand, what kind of seam sealer did you use around your cowl panels and cowl?
