Strange Noise?????
Old Jul 21, 2007 | 11:33 AM
MrMainEvent24's Avatar
MrMainEvent24
Default Strange Noise?????
I have a 64 1/2 Mustang 289 - 4 speed.
When I am cruising in 4th gear there is a strange chirping noise that sounds like it is coming from inside the dash / steering wheel. I can't pinpoint the problem, and the chirping gets louder and faster with the faster that I go. This just started happening last night. Anyone have any ideas of what this could be?
Old Jul 21, 2007 | 12:17 PM
jcomp's Avatar
jcomp
Default RE: Strange Noise?????
Speedo cable?
Old Jul 21, 2007 | 12:26 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Robins?
Old Jul 21, 2007 | 12:32 PM
66GTKFB's Avatar
66GTKFB
Speedometer and/or the cable. The cable has a tendency to get dry, aka loss of lubricant. The fix - remove the cable from the transmission end, wipe clean the inner cable, lubricate it with white grease (lithium) and return it. The other problem may be the speedometer itself, old age. The fix - replace it.
Jim
Old Jul 21, 2007 | 01:04 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Hamster wheel squeeking?
Probably not. Check the speedo or it could be something coming loose and vibrating. About once a year my interior panels in the rear of the fastback start chirping from the hardware starting to work loose a little bit, sounds kind of like a bird chirp. Grab your 1/4" socket set and screwdrivers, stand on your head under the dash and start checking.....
bjdutch2005
Mar 24, 2017 03:38 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
KingRando
Oct 2, 2015 08:06 AM
Emblazoned
Sep 3, 2015 10:45 PM
