Sway bar
Old Jul 22, 2007 | 07:12 PM
  #21
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: Sway bar
ORIGINAL: Oxnard Montalvo
I use a 1 1/4" hollow light weight sway bar from Cobra Automotive in Wallingford Connecticut. It was pricy and I had to grind an arc in the lip of the frame rails for added clearance, but this bar made a hugh difference over the stock 13/16" GT bar when combined with the Global West 150lb rear springs, urethane bushings, and heavy duty shackles. I find no need for a rear sway bar.
I also did the "Shelby Drop," installed 600lb front springs and a quick steer kit with the rollerized idler arm.
I have pretty much the same setup, yet to complete the shelby drop (but that's next)
I have a rear sway and I am about to take it off...IMO it is making the rear hang on for longer but then when it does go it gives no warning.
Turning the wheel while parking is a workout, and the rollerized idler arm doesn't bring the steering wheel back to center if you let go of it after taking a corner. Gotta do that yourself.
+1 on the biatch parking. I corrected the non centering with wheel alignment specs and new bottom ball joints.
Old Jul 23, 2007 | 12:32 PM
  #22
67 evil eleanor's Avatar
67 evil eleanor
I like the 1" Shelby drop with a 1 1/4 front and 3/4 rear. I also have Shelby type traction bars. The car is flat in the turns and drives well. I have the alignment as follows, tow in 1/8, caster +2, camber -1. It will give some premature wearing of the tires, but it hangs well.
Old Aug 24, 2011 | 05:57 PM
  #23
Frontsight1's Avatar
Frontsight1
Default Original GT Sway Bar
Does anyone know where I can score a sway bar for a '66 GT? The original sway bar is 13/16" and it was damaged by a previous owner. All I can find for an original replacement is 11/16".
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
Sep 16, 2015 07:53 PM
