i need help with a decode
Old Jul 22, 2007 | 01:07 AM
IM RICKY BOBBY's Avatar
IM RICKY BOBBY
Default i need help with a decode
hi again, a while back i posted about having a cleve that i was gonna rebuild, i was gonna take it out of a 72 mach 1 which had been totalled, well for some reason i decided i was going to look up the vin # and so i did a serch on the forum and got a good web site for the vin and it turns out i have the Q code for the engine which indicates i have or had a 4v cleve, as well as the plant body style and unit #
is there a difference between the cleve 4v and the boss cleve??? like maybe a 4v high output or something like that?
thecode plate thatis located on the side of the doorwas removed by the previous owner, i wanted to know if a plate like that is located anywhere else on the car, cuz if not the only thing i have to go by is the vin#, would the vin be able to tell you all the other stuff such as rear end, original color, ect...??
i was hopeing to get all the fact i could on this car before i remove the engine, though its a long shot, if its a diamond in the ruff, i wont use the engine.... i guess it all depend on what is found out... any help would be appreciated.. thanks guys
Old Jul 22, 2007 | 01:11 AM
mat11089's Avatar
mat11089
Default RE: i need help with a decode
as long as its a 67 or up u can order a Marti report.tell ya everything u need to know
Old Jul 22, 2007 | 03:22 AM
deadmanrob's Avatar
deadmanrob
hey man i hope these sites help you they did me brotha hit me up if they do
http://www.greatoldcars.com/mustang%20decode.htm
http://www.decodethis.com/VINDecoded...in=0T01F125663
Old Jul 22, 2007 | 07:22 AM
andrewmp6's Avatar
andrewmp6
boss 302 are a g code i believe and the 71 351 is a r code the boss was made 69 70 and 71 not a 72 once the door tags gone most of the info is gone with it. engine and tranny are in the vin i think rear end has a tag on it saying what it is other stuff like car color and interior your kinda left gussing.the q code is the low compression 351c cobra jet. see if you can get the block codes from behide the starter should be a D2AE-CA.
Old Jul 22, 2007 | 12:14 PM
IM RICKY BOBBY
thats kinda what i meant, so that would be a"r" code, ok well i have the Q so well im going to go over to my parents house where its parked and ill get the engine code and ive got my fingers crossed...
deadmanrob.... hey those both worked for the vin but niether told me anything about the door tag, as andrew said once the door tag was gone, the info it lost, i was hoping to find out that info, i really wanted the know what the rear end was and engine,
well im off to my parents house, if anyone else knows how i could find out the door tag info please let me know, ill post when i get back about the engine thanks...
Old Jul 22, 2007 | 02:21 PM
jaw66's Avatar
jaw66
In 72 they had the r-code cleveland. In 71R is the boss 351 in 72 it is the 351 h.o. I beleive they came with solid lifters. In 72 they built somewhere in the neighberhood of 400 r code mustangs
Old Jul 22, 2007 | 03:12 PM
IM RICKY BOBBY
ok so i got the engine code and it is D2AE-CA, does that mean it is the low compression cobra jet or what????
i also got the #'s off the rear end if anyone can help me with those i would appreciate it. the tag has about 5 different sets of #'s thanks lucas
Old Jul 22, 2007 | 03:18 PM
atomsk680's Avatar
atomsk680
http://bradbarnett.net/mustangs/time...3/72/index.htm
Q code 351 cobra jet
Old Jul 22, 2007 | 03:56 PM
1rareX's Avatar
1rareX
If you go to martiautoworks.com you can give them the vin and for about 20 bucks he ( Kevin Marti) will give you all the info you need . for about 50 to 200 dollars he can give you a complete build sheet and reproduction door tag.The report includes all options , paint , trim , interior , tranny , motor , type of interior material, all colors , type of tires , size of rear end , order date , build date , build plant , dealer address who sold it etc...phone him if you want , 623-935-2558 ,and they will put a rush on it good luck Bill
Old Jul 22, 2007 | 04:21 PM
1rareX's Avatar
1rareX
one more thing , are you familiar with a "buck Tag" , that was a small metal tag sometimes attached at the radiator support near the battery or on the side of the radiator support . if your car is intact , not wrecked or replaced ... you might look in those areas and give us here on the forum any numbers and letters you find and we can probably give you the info you need from the buck tag. Bill
