rear quarter window handle not coming off
Old Jul 24, 2007 | 02:21 PM
jts302's Avatar
jts302
Default rear quarter window handle not coming off
so i went to take my rear quarter window handle off and cant is there a special way of doing this i took the little grub screw and tried to pull and it wont come off
Old Jul 24, 2007 | 02:25 PM
66GTKFB's Avatar
66GTKFB
Default RE: rear quarter window handle not coming off
What year Fiat are you trying to remove the window regulator handle?
Jim
Old Jul 26, 2007 | 09:05 PM
jts302's Avatar
jts302
its a 65 and yes i am
Old Jul 26, 2007 | 09:09 PM
andrewmp6's Avatar
andrewmp6
do you have the little tool to remove the pin thing that holds the handle on.unless it has a screw unsure on a 65.
Old Jul 26, 2007 | 09:16 PM
shikoz's Avatar
shikoz
I thought 65 have those clips that hold the crank onto the shaft. If this is the case and if you don't have the tool for such removal, you can try to use some needle nose pliers and pull the clip, or use a flat head screwdriver and push the clip. good luck
Old Jul 26, 2007 | 09:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
The rear quarter window crank is secured by an Allen screw. You need to have a good set of many different sizes because this guy is small.
Old Jul 26, 2007 | 10:40 PM
66GTKFB's Avatar
66GTKFB
If it is a true 65 car, a 3/32 long allen wrench to reach the screw on the inside of the handle part. It the car is a 64, it uses a special removal tool.
Jim
Old Jul 29, 2007 | 06:39 PM
jts302's Avatar
jts302
i took the screw out but it still doesnt come off
Old Jul 29, 2007 | 11:15 PM
66GTKFB's Avatar
66GTKFB
If the handle is going to be replaced, give it a hard tapin and then pry it off from several sides. Repeat if necessary. You might want to put a piece of sheet metal or wood under the prying tool.
If the handle is not to be replaced, gently tap on it and pry away.
Jim
Old Jul 30, 2007 | 04:01 AM
blueovalboy7's Avatar
blueovalboy7
ORIGINAL: 66GTKFB
Jim
That's exactly what I was thinking, essentially using the method I use to get the caps of jars that are very tight, tap around the edge and wiggle it, hopefully you were planning on replacing them anyway. If that doesn't work then you will have to pry it out, just make sure and protect the panel.
drfister
May 3, 2018 10:38 PM
Roger Mabry
Jun 15, 2016 08:27 AM
spectreman
Mar 31, 2016 09:26 PM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
