Carb Question
Old Jul 24, 2007 | 11:53 PM
rogula's Avatar
rogula
Default Carb Question
When I depress the gas pedel all the way (replicated by manually pushing the lever on the carb) a small amount of fule spills(squirts) from the front of the carb. Is this normal (I don't think it is).
Probably a stupid question but I don't know, can a carb be repaired or should I just get a new one?
Old Jul 25, 2007 | 12:16 AM
66GTKFB's Avatar
66GTKFB
Default RE: Carb Question
Accelerator pump diaphram is shot but without the engine and carburetor types, it's a little difficult to say.
Jim
Old Jul 25, 2007 | 12:24 AM
rogula's Avatar
rogula
Engine is a 289
Carb is a Holly 2bbl but can't find model number on it (I only bought it 6 weeks ago).
I can see that where the gas is leaking from there is a plate with 4 screws. The lever enters that plate and there aprear to be a black rubber piece sandwiched between the carb body and the plate.
Old Jul 25, 2007 | 12:30 AM
JMD's Avatar
JMD
ORIGINAL: rogula
Engine is a 289
66GTKFB nailed it,,,,, and you confirmed it, you should be able to get a new accelerator pump (or diaphram?) for your carb, I don't know where, but someone here will....
I am assuming that you bought the carb used right?
Old Jul 25, 2007 | 12:35 AM
66GTKFB's Avatar
66GTKFB
Post a picture.
Jim
Old Jul 25, 2007 | 12:36 AM
rogula's Avatar
rogula
Carb was on the car when I bought it. There is a decal on the carb that say's "remanufactured by holly", which is how I knew it was a Holly.
Old Jul 25, 2007 | 12:39 AM
66GTKFB's Avatar
66GTKFB
Not necessarly. It may be an Autolite. Holley was just a facility that did the work. One of my distributors was rebuilt by a GM owned company.
Jim
Old Jul 25, 2007 | 12:44 AM
JMD's Avatar
JMD
ORIGINAL: 66GTKFB
Jim
+1000,,,, "remanufactured by" means nothing as it relates to original manufacturer....
I will give 5 to 1 odds that it is an Autolite....
Old Jul 25, 2007 | 12:55 AM
rogula's Avatar
rogula
Good to know, thanks guys....
the next question....
Is it worth fixing or should I replace? What's a good "basic" carb. Is it worth going 4bbl without changing anything else in the engine? Manual Choke or electric.....
Old Jul 25, 2007 | 01:01 AM
JMD's Avatar
JMD
ORIGINAL: rogula
Depends what you want from your car. It will be both cheap and simple to repair your existing carb, (prob about $20 for parts, and you can fix easy) going 4 bbl will cost lots more, and be a lot more work. And yes you can go 4 bblwith just a carb and manifold change, no other changes needed, and I like elec chokes....
