69 widshield wiper motor
Old Jul 26, 2007 | 06:15 PM
eep4life's Avatar
eep4life
Default 69 widshield wiper motor
mine seems to have stopped working. does any one know where it is located and how to remove it..... and where can i find a new one
Old Jul 26, 2007 | 06:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 69 widshield wiper motor
Look under your dash near the steering column. Check with just about any Mustang vendor of your choice to find a new one.
Old Jul 26, 2007 | 11:58 PM
Cruzzar's Avatar
Cruzzar
The motor can be removed after you remove the cowel cover (the piece of metal immediately in front of the windshield). The motor comes out from outside the car and not from under the dash. I believe the '69 is the same as my '70. I would double check the switch, fuse and connections with a volt-ohm meter before removing the motor.
Old Jul 27, 2007 | 12:56 AM
4reboy's Avatar
4reboy
ORIGINAL: Cruzzar
That's correct. Take out the cowel cover, and undo the 3 bolts around each wiper blade spot, and there is 3 bolts on the bracket for the motor. Drop it all then slide it out through the big cowel hole as an assembly.
EDIT oh yeah and be sure to unplug the wiring and push the gromet through the hole.
Old Jul 27, 2007 | 04:19 AM
eep4life's Avatar
eep4life
ok thanks... oh real quick i dont have a manual.. where is the fuse for the widshield wiper motor... befor i remove it i want to check everything
Old Jul 27, 2007 | 03:41 PM
4reboy's Avatar
4reboy
I'm not sure, look in the FAQ for wiring diagrams. You can always replace all the fuses for peace of mind, thats one way haha
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Drastang
Sep 30, 2015 03:48 AM
logan409
Sep 26, 2015 07:43 PM
