Engine Stroking Wonders.......=] & Mileage?
ok .. where can i find info on gear ratios etc.. for everything else .
to tune in with every other aspect of the car from rear to engine etc..
yeah .. once you get to the point of spending that much money to get that kind of torque ...
Gas prices are irrelavant .. unless your a DD ... which i wont be with this babe ..
it will be a SEmi DD.. hahha.
gotta have fun with it ya know ?
did you buy your kit online ? or did you buy it at a local shop?
I bought the kit over ebay,,,The Mustang Depot had the best value deal,,,,they were helpfull and sent me a good product..
I did a lot of "shopping" over summit racing, and almost bought from them, but found similar products for less on e-bay, so I went that way. I like to shop over Summit because it is very easy to negociate their website. Get an idea of what you want then go "price shopping"
http://cgi.ebay.com/ebaymotors/ALL-F...mZ180129561984
http://store.summitracing.com/egnsea...115+4294870257
hmm ok thanks alot ... that mustang depot in riverside is about 1 hour away from here .. i might give it a visit .
when stroking dont i need new heads? do i keep 351 w heads?
also is there any boring involved in this whole process?
ORIGINAL: takeoutexodus
I like dealing with local shops,, but the speed shop here in Las Cruces deals with Chevrolet..... not Ford... so everything was purchased online.Ratios and such can really only be determined with what you want from the car,,, frankly I think that my son and I may have gone a little too hot on his 66, but it is going to be a hoot to drive!!!!!!!!
Comp Cams HR294, 10.5 to 1 Compression ratio, RPM air gap manifold, Victor JR heads, roller cam & rockers. 750 Demon carb, 5 speed tran and 4.10 gears... I don't think it will go on a lot of long trips....
You can almost count on boring the block to .030 or .040 over, but you would normally do this on a rebuild as well.
If going to the expense of a stroker, you wont want to try and save boring the block.
Do you haveyour 351heads now? If so, let me knowwhat you have and I can run some goodies through my computerto try and findthe piston specsyou will need to get the compression ratio you are looking for. I have a set of 1970 iron heads that I can give you if you will use them, I think the 70 heads are supposed to be pretty good, and these were on a running engine...
Well I have a local friend who owns his own shop ..
I think im going to gather my knowledge .. and then set up a play book with him ..
head recommendations?
edelbrock intake i assume.
i have no clue what roller cam and rockers are ...
but otherwise ....so should i just buy a 351 block and work it from there? cuz i think its pointless if i buy the whole engine right?
tko 500 or tko 600 ?
.A roller cam is a camshaft that uses "roller lifters" instead of flat lifters, the roller lifters have a small roller or "wheel" on the bottom, this roller rides on the cam shaft, allowing valves to open and close in a more aggressive manner.
TKO 600
hmm ok .. thanks alot ...
wow . good deal!
Well i will take your advice in hopes of pushing 450 hp and 500 tq.
cant wait ..
if you have any other suggestions let me know .. thanks .
wow . good deal!
cant wait ..
And well i have 69 heads .. so i think they are just as good ..
but all this will develop in the next few months .. so ill let you know how it goes ..
btw new or used tko 600?
thank again.
thank again.
thank again.
thank again.
The TKO was new...
