Spring Compressor help!
Old Jul 28, 2007 | 04:13 PM
shikoz's Avatar
shikoz
Default Spring Compressor help!
I've go thte type of compressor that slides in the middle of the spring. I go the spring out. While undoing the compressor (to let go of the spring) two of the claws slipped. It's loaded. any tips on how to deal with this!!
ASAP!!!!!!!!!!!!!!!!!!!
Old Jul 28, 2007 | 04:16 PM
shikoz's Avatar
shikoz
Default RE: Spring Compressor help!
If I keep losening up the compressor, it looks as thought the other claw is about to slip. ANY HELP???!!
Old Jul 28, 2007 | 04:19 PM
06triplevalve's Avatar
06triplevalve
Honestly I would pick it up with a broom handle and take it to a lidded trash can and buy a new spring. It is loaded, as you mentioned, and it just ain't worth it. Not what you want to hear, but what I think is right.
Some people would try to wrap wire around and around, through the spring, without touching it, on both sides of it, and then start messing around, but I wouldn't. that's just me though.
Good luck, and be safe!!!
Roy
66GTKFB's Avatar
66GTKFB
Try tightening it up a little then undo the opposite side. Work it back and forth.
Jim
Old Jul 28, 2007 | 04:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yep, put it in a big trash can with a lid and stay away from it. That is a loaded gun that's about to go off.
Old Jul 28, 2007 | 04:35 PM
shikoz's Avatar
shikoz
I got it!! Thanks you guys! I compared the coil in distress to the coil I already took out and noticed it had about an inch to go. I placed a solid metal rod perpendicular to the coil so it wouldn't go flying. Reviced it. and kepp loosening up. On the third turn, it shuttered just a bit (nothing compared to my Mossburg 12 g!!!!). Still, the situation had my blood flowing!
Again, thanks!! Now here comes the Grab a Tracks!
wheeeew.
Old Jul 28, 2007 | 04:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
I can now breathe a sigh of relief that I don't have to attend a funeral of a fellow Mustanger.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
fastbackford351
Oct 1, 2015 12:24 PM
mungodrums
Sep 28, 2015 10:54 PM
